1590LB template...?
Started by gasmask, January 11, 2015, 12:09:28 PM
gasmask
Hi guys,
my aim is to build LofoMofo in 1590LB (like Henretta Engineering).
I mean two trimpots inside, only jacks and dc jack are not mounted to board.
Do you have any template for eagle or any tutorial how to design a board for 1590LB?  ???
Thanks in advance  :)
i guess you would have to create it as a new lib part...
maybe if you can edit a 1590bb ?..then save as a new part.. :icon_idea:
peterg
I created the layout for this board on Inkscape. I'll post a link to the file if someone can tell me how to.
http://www.diystompboxes.com/smfforum/index.php?topic=36392.msg995579#msg995579
gasmask
#3
Probably you have to upload it on mediafire.com or sth like that.
What kind of 3pdt switch did you use?
Edit: And of course, do you have more gutshots? I mean, which jacks did you use and how did you wire it inside?
peterg
http://smallbear-electronics.mybigcommerce.com/cic-blue-3pdt/I'll see what I can do. The footswitch is a standard CIC blue 3pdt from small bear.
