Comparous oscillation
Started by EfarmosmenosStokos, January 14, 2015, 03:47:41 PM
EfarmosmenosStokos
Hello all,
I'm having a problem with a Comparous PCB I etched from tonepad. I assembled the board and powered it to check if it was working properly.
What I get is a very fuzzy and gated guitar that reacts to the sustain knob, and a steady wobbling sound like a metronome, even when there is nothing plugged in the input.
The wobble does fade with the level control and settles with the trimpot.
diagram: http://www.tonepad.com/getFile.asp?id=9
Any help would be much appreciated
EfarmosmenosStokos
Some more observations:
There was no sound or noise when I removed the first transistor Q1.
Q1 VCE was 6.67V with 10.97V power supply
Q4 and Q3 VCE around 9.23V
Q5 VCE 0.590V
Q2 VCE 0.002V
> Q2 VCE 0.002V
All _three_ voltages to ground on Q2, please.
And anticipating a *very* common problem.... where did you get your '3080? The market is flooded with fakes.
EfarmosmenosStokos
Thanks for the reply, I will report the voltages when I get back home tomorrow.
IIRC, I purchased the chip from BanzaiMusic.com in Germany. Is there another online supplier you could recommend for a chip?
EfarmosmenosStokos
I tried to measure the three voltages, but they were all fluctuating greatly. They were slowly oscillating around the following values:
VEG 0.0 - 0.03 V
VBG 0.0 - 0.06 V
VBG 11.50 - 11.70
I switched Q2 with Q1 around, but the same problem persisted.
Any help or ideas on what I may have done wrong?
I have redone all the soldering on the back, switched all the transistors around, but to no avail.
The 3080 is supposedly from a trusted online shop in Germany, so I don't know what to make of this. Next step would be for me to purchase a digital oscilloscope and follow the signal along the circuit.
Please help me :)
> Please help me
We can't see your probes. Please proof-read your report:
> VEG 0.0 - 0.03 V
> VBG 0.0 - 0.06 V
> VBG 11.50 - 11.70
"VBG" is zero? Or eleven?
Point "Vb" (junction of 56K and 27K) should be around 3 Volts. Is it?
The Q2 Base to Ground voltage should be a little less. Is it?
If the IC is socketed, remove it, and test Q2 Base to Ground voltage again.
There have been too many reports of bad '3080s from otherwise trustworthy shops. There are tons of fake '3080s and maybe the shops do not have a way to test them. The only '3080s today that I would trust without reservation are from Small Bear. There may be other known-good sources.
But if it is not a bad chip, then 98% of the time it is a "wiring problem". Hair or whisker of copper on the PCB between two traces, bad solder, etc etc.
EfarmosmenosStokos
Sorry for the typo, I took another measurement today:
My powersupply is 11.40 Volts.
Vb is at 4.1 so that would be around 3V if my PS were at 9V.
My voltages were steady today, Perhaps I need a new multimeter.
VEG at 8.21V
VBG at 8.89V
VCG at 8.23V
I doublechecked, turned on and off, and even switched transistors.
So, no, my Q2 base to ground is higher(!) than Vb by more than 4.7V.
I removed the CA3080 and measured VBG at 3.7V, while Vb was at 4.1V.
Would that be an issue of fake 3080?
Thanks for your time, PRR
Are both input pins on '3080 at the *same* voltage?
EfarmosmenosStokos
I measured pins 2 & 3 on the PCB as per the datasheet and both inputs had the same voltage, with or without the 3080 in its place.
~5.3V with, ~6.0V without the 3080 in place.
Get a genuine '3080. I suggest SmallBear.
