novice question regarding wire types
Started by tacomamc, January 31, 2015, 01:00:56 PM
tacomamc
I recently made a fuzz face clone using a 2222A and 2n3904 transistors, and I really like the results.  Im going to build another, but for now i want to make this one a little better.  Im happy with my work on the PCB (I used perfboard), but the wiring from the perfboard to the pots, switch, and jacks is what I'm asking about.  I used thin solid strand wires I took from an old phone line.  I know it gets brittle if you do much moving of the wires around... such as for replacing the battery and such.  So, would I be better off using multi strand wire?  I have some that is more robust, I think its 18 or 22 gauge?  I got it in a three roll pack from Lowes a while back.  Would this be ok/ better to use for the runs to the jacks and pots?  Im hoping that by cleaning up my wiring I can also reduce some of the noise.  Its not bad, but right now Im using a Telecaster with single coils, and actually only have a neck pickup, so it may just be amplified single coil hum that I'm hearing.  I guess when I can afford bridge pickup, I will be able to verify this.
peterg
Stranded 22 or 24 gauge wire is the most commonly used.
GibsonGM
Quote from: peterg on January 31, 2015, 03:03:16 PM
+1    Parts that aren't going to move, on the PCB, anything is fine. But for batteries, offboard connections, I find that stranded wire holds up a lot better, too.   And - if you kink or strip too deeply on solid core, it will eventually break...
22awg stranded be perfect, 18awg would be massive if that's what you have. Roll the volume of your guitar off while plugged in with the pedal engaged to hear how much the single coil is contributing to he noise and how much is pedal noise.
dave
tacomamc
Thanks everyone for your input.  I'll make the change to the stranded wire I have.
