2n5457 static protection diode
Started by acehobojoe, February 05, 2015, 12:57:09 PM
italianguy63
Traces at Q1 are all cramped too...  MC
antonis
#21
Quote from: alanp on February 05, 2015, 07:31:31 PM
Pretty small holes and pads for components, there.
And super extra tiny traces... :o
(risky for toner transfer and waste of etching solution and time...)
@ acehobojoe: You have to "play" a little with your own custom settings...
acehobojoe
what is a good pad size and hole size for average components?
armdnrdy
Quote from: acehobojoe on February 06, 2015, 01:46:37 PM
It depends on how component "busy" your board is. Same with trace size.
There are tutorials on the web..and R.G. wrote a book on the subject: PCB Layout For Musical Effects
http://www.goodreads.com/book/show/15747109-pcb-layout-for-musical-effects
http://smallbear-electronics.mybigcommerce.com/pcb-layout-for-musical-effects/
bloxstompboxes
I have R. G.'s book and can vouch for its excellence. Really educates or reminds you of the stuff you learned in school and the stuff you didn't. I use .08in outer diameter for my pads and .02in width on traces. I etch though so you could go smaller on the trace width for fabbed boards, and maybe even on the pad diameter. I just use that size diameter so I can drill most pads with a #59 bit and not have worry about whether the leads on a component will fit or not. I hate changing to a lot of drill bits throughout a project.
acehobojoe
I'm getting that book! I must have it.
acehobojoe
bloxstompboxes
Steve should have it at smallbear. http://smallbear-electronics.mybigcommerce.com/pcb-layout-for-musical-effects/
A bit expensive but I guarantee you'll like it and learn a lot. It is a little dated as far as the enclosures it talks about and software available but it's still awesome.
