Phase 90 debugging help needed
Started by Xavier, February 23, 2015, 05:22:28 PM
Xavier
I just built the Phase 90 according to Sabrotone's layout here http://www.sabrotone.com/?attachment_id=222 . It's been done following the Tonepad schematic.
I used matched 2N5952 transistors, so it really sounds good. The only problem I have is that it sounds a bit distorted (both in Script and block mode) on the clean notes, I mean like if you were using a low gain overdrive on top of it. Enough to bother me.....  >:( . I am not able to find anything ,,,,,,,,,,
Here are my voltages in case any kind hearted person is willing to help... thanks in advance !!
V:   9,18
Q1
D:   4,39
S:   4,39
G:   2,06 - 2,36
Q2
D:   4,4
S:   4,4
G:   2,07 - 2,40
Q3
D:   4,4
S:   4,4
G:   2,07 - 2,41
Q4
D:   4,4
S:   4,4
G:   2,08 - 2,40
Q5
C:   2,6
B:   3,82
E:   4,4
IC1:
Pin 1:   4,4
Pin 2:   4,4
Pin 3:   4,4
Pin 4:   0
Pin 5:   4,4
Pin 6:   4,4
Pin 7:   4,39
Pin 8:   9,19
IC2:
Pin 1:   4,4
Pin 2:   4,39
Pin 3:   4,4
Pin 4:   0
Pin 5:   4,4
Pin 6:   4,4
Pin 7:   4,39
Pin 8:   9,19
IC3:
Pin 1:   4,4
Pin 2:   4,4
Pin 3:   4,21
Pin 4:   0
Pin 5:   3,6 - 5,36
Pin 6:   3,79 - 5,34
Pin 7:   1,27 - 8,58
Pin 8:   9,19
thomasha
check the output transistor,
There is a 150k resistor, you can change it, but you will lose some volume.
I build one of those with solderman's layout and used a different output transistor.
Don't forget to check the first opamp stage, maybe that is causing the distortion.
take a look here:
http://www.electrosmash.com/mxr-phase90
to understand what does what in the pedal,
and you can also make an audio probe:
and follow the signal chain. It will be easier to find where it's distorting.
Thomas
Xavier
Thanks for your suggestions .......will do and will post my results here !!
Xavier
#3
OK.....
- Subbed the 2N4125 by a 2N3906
- Redid all solder joints
- Triple checked component placement and value.
Still the same... this is on "script mode",,,,,,in "block mode is even worse
Here's a sound sample direct to PC. 1st half dry, 2nd half with the effect on.
https://soundcloud.com/xavier-martinez-6/phase-test
It phases quite nicely, but I have this ugly distortion underneath... I have also noticed some volume boost.
Any idea what could it be ?
thomasha
I would say too much gain at the output transistor, or input opamp,
the rest of the circuit just makes the phase thing,
when i first built mine it had a lower output than bypass, i changed the final transistor's resistor and it sounded louder.
Check also the tonepad build report, sometimes there is something about this.
