Simple stutter/automated killswitch pedal
Started by Mind Flayer, February 25, 2015, 04:10:13 PM
Mind Flayer
I am interested in building a very simple stutter pedal that would basically sound like an automated kill switch. Aside from the footswitch to turn the effect on and off, the only control would be one knob to control the speed of the effect. Anybody have any ideas on how this would be done?  Thanks
nocentelli
Brisance
Maybe a MOSFET in a voltage divider configuration with a 555 output going to the gate?
GGBB
Quote from: nocentelli on February 25, 2015, 04:28:43 PM
Like a choppy tremolo?
+1
Any tremolo that can do decent square wave and goes both slow enough and fast enough as well as deep enough for your purposes.
Gus
GGBB
Quote from: Brisance on February 25, 2015, 04:59:01 PM
The Tiny Tremolo uses a 555 to drive an LED/LDR - very square and a simple circuit:
http://www.diystompboxes.com/smfforum/index.php?topic=87322.msg840206#msg840206
FUZZZZzzzz
There was a discussion here about the utter stutter pedal. Maybe breadboard this?
http://ilovefuzz.com/viewtopic.php?f=151&t=32044&sid=691cfbdf5865ed0c9bda909e801704ad&start=15
bad drawing I know, but it should give you some ideas.
smallbearelec
+1 re a square-wave trem. My Tremulous Bear will do this:
http://diy.smallbearelec.com/Projects/TremBear/TremBear.html
You might also want to experiment with a Repeat Percussion Device like either the Moosapotamus Skippy:
http://www.moosapotamus.net/ideas/skippy-tremolo/
or this idea I came up with:
http://diy.smallbearelec.com/Projects/RepeatPerc.gif
Time to pull out the breadboard and find what makes you happy.
GGBB
smallbearelec
Quote from: GGBB on February 27, 2015, 02:31:35 PM
Quote from: smallbearelec on February 27, 2015, 07:05:39 AM
Cool! What is the value of the top resistor in the LFO?
I can't believe that I forgot to write it down when I was trying it out. However, you will be breadboarding this anyway, so experiment to find a value that gives the upper speed limit that you want.
danielzink
snarblinge
Thanks danielzink, I clicked in just to see if this had gone that way.
Jack White III
b.
snarblinge.tumblr.com
