remote footswitch with LED for boss style bypass
Started by Johan, February 26, 2015, 03:44:58 AM
Johan
Longtime members of the forum might remember Mark Hammer pointing out how easy it would be to make boss style fx switching remotely controlled.
its a great trick when your delay sits in the loop on the back of your amp, but I allways missed the LED
here is a simple solution I came up with. Im sure soemone can come up with a more elegant solution, but this one works and I've used it reliably for a few weeks now..
https://www.youtube.com/watch?v=BxX5IQpvMko&index=1&list=UU-1YU-vAhYX2s-46Q93sWqw
the only thing that doesnt work is "double tapping" as many does to check if there is Power to the fx. the reason for that is the 0,1Uf on the transistor base to ground. it is there to prevent false triggering from bad switches "bouncing" Before making or breaking contact.  with given value you can only switch your FX ~2 times every second  ;)  you can reduce value, but at some Point risk false triggering.
enjoy
J
DON'T PANIC
JFace
turkey101
Hi Johan - I'm looking at doing something similar, but the images in your post have disappeared.
Is it possible for you to post them again, please?
turkey101
