Choosing Speaker for multi channel amp
Started by fatecasino, March 03, 2015, 02:30:53 PM
fatecasino
Hi all,
after really long time I managed to fix my first multi channel amp ~22Watt (it's based on Taylor's tiny giant). I connected it to  a 30 watt 12" Vox guitar speaker.
2 channels are for instruments and 1 channel is dedicated to voice microphone.
Guitars and basses sound fantastic  :), I really love this thing. My problem is that due to the speaker the microphone sounds not so good. Lots of frequences are missing and the voice sounds a bit like jamaica's studio one recordings. Not bad, great sound personality, but I would like something more crystal clear voice sound. It's definetely the speaker, because if I connect the amp line out to an active speaker the voice sounds GREAT!
So, are there any other speaker options? Is there 30w 12" speaker that would give me this sound? full range?
If I add a passive cross over and a horn, will I get better results?
PBE6
I think you're going to have enormous difficulty finding a happy medium. Vocals sound most natural through a hi-fi system (usually as clean as possible and with a wide frequency range), while guitar cabinets are all about colour (most notably with high-end roll-off starting somewhere around 5-6k, but also with the peaks and dips associated with construction materials, cabinet geometry, damping, speaker response, etc..).
Maybe the best bet is to make the cabinet as hi-fi as possible, then add a speaker simulator inline with the guitar input? Even with that approach I'm not sure you're going to love the sound, but I don't think installing a "hi-fi" simulator for the voice channel is even viable from a physics standpoint.
GGBB
Quote from: PBE6 on March 03, 2015, 03:02:54 PM
+1
Even bass guitar is not usually friendly toward guitar speakers as their dynamics at the low end can damage a typical guitar speaker. But bass and vocals can play nicely together through a 2-way PA-ish setup. I'd aim for what works best with the vocals and allows for deep bass, then tweak EQ for bass and do cab sim for guitar. I suppose some bass cab/amp sim couldn't hurt either.
Voice through guitar speakers often sounds "old time".
Voice+guitar, through the same amp and speaker at high levels, will distort each other badly.
If good vocals matter, use a separate system.
As Gord says, pre-effected guitar and clean voice through a well-powered PA works very nice. But that is a step up from Tiny Giant technology.
fatecasino
