Tube power amp simulation
Started by Sheldon, March 05, 2015, 02:42:15 PM
sajy_ho
#20
It seems nobody from experts gonna explain it so a word from the idiot guy: :icon_mrgreen:
Actually both even order and odd order harmonics can be musical, kind of...
The warm feeling of the tone is about how much harmonics is added to the raw guitar signal. let me explain it this way, 2nd order harmonic is always the same as original note but one octave higher, so definitely it's musical. 3rd order harmonic is not the same note as original note but that doesn't mean it's not musical, because it will be always another musical note and will form a chord with original note, so on 4th and 5th orders...
But higher orders mostly aren't related to any musical note and tend to add some junky,fizzy,... taste to the tone.
So why tubes are more musical? That's because they tend to add a huge load of low harmonics (musical ones) to the signal and a little high order junk! And they do it in both clean amplification and clipping, but at higher signal levels and especially clipping condition the amount of generated harmonics will rise and the sound will get warmer and warmer.
Transistors work in another way, they do not add much harmonics to the signal at clean level, and at clipping they produce a huge load of ugly harmonics (high order ones).
Even order harmonics are produced by any type of assymetrical amplifier stage, like a triode gain stage, phase inverter, SE output stage. So if we want to generate even orders with transistors we need a "Clean Assymetrical Amplifier" stage.
PP output stages form a composite curve, and they tend to amplify the signal nearly symmetrical so they will cancel out the most of even orders, but odd orders still are there and they are part of PP tone!
I think it's best to focus on a particular amp's output stage and try to simulate all of its characteristics...
Life is too short for being regretful about it.
highwater
I had a similar idea, about a year ago. I read somewhere that the JFET transfer curve is more like a pentode than like a triode, and combined with the knowledge that tube amps are almost-always transformer-coupled, threw a JFET phase-inverter at a RadioShack transformer into a corner of my breadboard. It barely worked, and only sounded slightly better than crap, but was functional enough that I drew-up a generic class-AB push-pull power-amp topology in a sim. According to SIMetrix, it should work... I'm hopeful, seeing as I also simulated the proof-of-concept circuit, and the sim told me that *that* would never work (to be fair, I did have to crank my amp to even get bedroom-level output).
That sim file is on my other (currently broken) computer, though, and would almost certainly sound bad without tweaking anyway... meanwhile my breadboard has been perpetually occupied with pre-build tweaking of known-good circuits, so the project has stagnated. I expect to be finished messing-around with CMOS overdrives and/or buy another breadboard (or several) by the end of the month, though, and will at that point resume work on the concept.
CAVEAT EMPTOR:
This is *way* above my pay-grade, but on the other hand, it's also the exact reason why I hope my boss (me) will one-day give me a promotion. I assume there's a reason why my idea hasn't been done to death, but I'm the stubborn sort, and I've found that prop-wash is quite effective at keeping dust bunnies out of a car's engine bay, so I'm quite content to persist anyway... even if it's a fool's errand, I'm sure the topological similarity to a real tube amp will at-least give it some mojo ;).
"I had an unfortunate combination of a very high-end medium-size system, with a "low price" phono preamp (external; this was the decade when phono was obsolete)."
- PRR
Sheldon
#22
I have to admit I'm totally lost and I don't know where to start !
If I understand correctly, if I want to simulate the effect of the power amp stage in a modern push pull amp, I have to :
* split the signal
* invert phase of one side with a inverter op-amp
* use different diodes to do assymetrical clipping =>simulate Tube grid bias shift and Tube distortion (only first orders even and odd harmonics)
* combine the signals (substract???) so remains the signal with mainly third and some fifth order, and a little bit of second and fourth order, to simulate the fact that a push pull stage is never perfectly symetrical
And then trying to simulate sag compression and current feedback?
I'm trying to understand KGM Micro Amp Schematics that J0K3RX suggested but I admit I have difficulties to understand each part.
http://milas.spb.ru/~kmg/files/projects/fetpa/micro/MicroSchSS.pdf
Sheldon
@ Johan : as I'm exploring each possibility cause I'm trying to learn how things work, what is the role of the b (lower case) polarity and how is it created?
Johan
Its the bias/4.5volt for the opamp
DON'T PANIC
Sheldon
thank you. In fact it's the top right part of your schematics that I don't understand. The b polarity runs through the 100k pot and depending of its resistance it gives a PP or SE character to the tone?
Gus
IMO
It has a lot to do with the output tubes, output transformer and speaker interaction.  This mess is hard to model
There are amps that are IC until the output transistor/tube transformer out
BJTs might be better to use instead of jfets for preamp gain stages
sajy_ho
Quote from: Sheldon on March 08, 2015, 10:34:48 AM
* split the signal
I don't think assymetrical diode clipping will do any favor in producing more even orders, because it's just clipping of "already symnetrically amplified signal". We need "assymmetrical amplification" to do this particular job. Also don't forget that tubes do have internal capacitances, so they will add low pass filters in the path.
Thecomedian
#28
See if you can find a PDF or hard copy version of The Stompbox Cookbook.
I believe that we've mostly figured out "tube sound" since people have tiny hand-sized amplifier emulator/simulators these days, but there is a section on the considerations of all the variables regarding what makes tubes sound "tubey". You might find it helpful if only as reinforcement. It may only be an analogue for a stomp box builder without software or hardware coding and microprocessors, but it can sound reasonably close.
I think rule #1 might be to prevent hard clipping as much as possible. In transistor terms, its the saturation or cutoff where no further changes take place. In preamp tubes and output tubes, as far as I know, no matter how hard they are driven, there is still at least a minimal change in the signal occurring at any given Time, because of the complex interactions of transformers, microphonics, operating point changes, etc. What is called soft clipping, the thing which tube amps sound is famous for, is the distortion of the signal so that it fails to follow the input accurately. Hard clipping, which happens because BJT transistors are so accurate at following input signal changes, is the point at which the signal completely stops following the input signal at all. Tubes still do follow, if at least highly inaccurately. I haven't really seen any information yet that shows true hard clipping in tube based amplifiers.
The section on tube emulation in TSC is a good read.
Quote from: sajy_ho on March 07, 2015, 06:09:27 PM
Definitely. It is my personal opinion that this is why metal is mostly power chords, possibly even where the term comes form, because with all that "power", you need to play fewer notes to have a sound that isn't garbled :P. After all, you're getting "extra notes" with the distortion, so you can play less on the guitar, and then use different combinations of the same notes of a chord for different musical sounds.
Quote from: Sheldon on March 07, 2015, 03:57:06 PM
I've always thought that depending how hard you drive it, the power amp section added a little bit of "warm distortion", less raw and more musical than the preamp one.
But I can't understand what is doing this.
As far as I can understand it, a push pull power tube section is attenuating most of the even harmonics, but I thought that it was those even harmonics that give the warm and musical tone?
Single output vs push-pull is also considered in TSC. Pre-amps are also given some attention. From what I remember off the top of my head, the claim was that more tubes in the pre-amp sound warmer because there's more cascading going on, softer clipping, than higher gain stages with fewer tubes. I believe the push-pull reasoning was along the lines of the shift in operating points, IMD, and such.
If I can solve the problem for someone else, I've learned valuable skill and information that pays me back for helping someone else.
Sheldon
thank you
One thing I find tricky is to simulate push pull amplification without actually amplifying the signal cause my aim is to have a line in and a line out
teemuk
#30
QuoteI think rule #1 might be to prevent hard clipping as much as possible.
A myth. People are brainwashed to this concept after they have been saturated with -drawn- images of what tube amps output in some weird imaginationland. Reality, that revelead by oscilloscope captures and such, is often totally different than drawn pictures.
If you actually scope output of a tube power amp you typically see plenty of hard clipping and other "nasties" like crossover distortion. Fortunately all this sounds much better than what it looks.
Given characteristic curves, pentode tubes are damn near FETs and beam tetrodes damn near BJTs so hard clipping is to be expected. Couple this to global negative feedback and hard clipping is guaranteed. So yes, tube power amps hard clip, like this Fender amp here:
...or like this Trainwreck clone here:
Actually when voltage can no longer swing upwards things just clip, whether they are BJTs or tubes. It's the limit. The tube isn't suddenly going to overcome it by some magic. If you look at it, tubes are equally limited by saturation and cutoff states. We can notice a slight "softness" in overall curvature of the characteristic curves but as I said, pentodes are damn near FETs and beam tetrodes damn near BJTs so don't expect miracles. The most prominent thing explaining why tube power amps behave like they do lies within the overall circuit architecture not in the active devices.
Besides, now that we talk about "change" in signal after sustained ovedrive we aren't neccessarily discussing about softness of clipping characteristics. Not at all. If you overdrive a typical push-pull tube power amp the signal will typically soft clip distort just a little then very quickly hard clip. THEN interesting stuff begins to happen: Voltages may sag due to increased current draw and this will furthermore reduce clipping threshold, making clipping even harder. Additionally voltage drop at screen circuit may introduce little bit of gain compression. Now the gradual voltage sags and increased distortion adds more and more harmonic distortion as overdrive sustains. It's not just static clipping to a static clipping threshold.
The signal is still hard clipping but due to such changes the clipping thresholds have changed, in fact they change in interaction with overtall signal envelope, and this affects harmonic patterns of the distortion. Continue overdriving and power tube grids begin to conduct and draw current, this both clips the signal at their grids and causes DC offsets (such as bias) change. This typically introduces crossover distortion to the signal so again more and more harmonics (now from crossover distortion) are getting layered to the distorted signal. Furthermore the harder we drive the power amp, we may have rising asymmetry in the PI output and other little details that have an effect on pattern of the harmonic distortion. Essentially we have several distortion/clipping mechanism that interact with overall envelope of the signal, not just with static thresholds of voltage. All this while our signal is still getting hard clipped, in fact all the time progressively more and more. Hard clipping does not exclude anything from this process. But we have a system where sustained overdrive not only increasas amplitude of harmonics but continuously changes the entire pattern of the harmonic distortion.
Preamps have similar mechanisms where clipping process is spread across multiple stages and asymmetry of clipping and capacitive signal coupling causes DC offset modulation. Such modulation naturally has further effect on overall asymmetry/symmetry of clipping and therefore also to harmonic patterns of the clipping distortion. The behaviour is totally different than static clipping to, say, just a single diode clipper where increased overdrive doesn't really change the harmonic pattern of the distortion per se, just increases amplitude of the harmonics.
Again, soft clipping is not a requirement. The phenomenon takes place as long as you have some asymmetric clipping and capacitive coupling between stages. In fact, if you break down a typical tube preamp it is quite common to find out that clipping in it happens in just one to three stages: Few of them clipping hardly at all and one practically clipping so much that it has nearly a square wave-ish output.
Thecomedian
#31
This is why I need to invest in oscilloscope. Thanks, Teemuk  :icon_biggrin: I believed in those squashed sine wave diagrams for "tube sound" mainly because FETs and tubes are not linear devices, and their gain tends to fall as their voltage swings get bigger.
How does the trainwreck clone compare to an equally overdriven BJT section? Does BJT maintain constant wiggle like on the plate of the clone?
Sheldon
Today I began simulations with LT Spice, especially Johan's project, but with no success!
kingswayguitar
teemuk
those are great scope shots. can you get a shot of a screen grid above/below a plate trace? been googling for one lately with no luck :) thanks!
Johan
Quote from: Sheldon on March 09, 2015, 05:09:19 PM
Is there an accurate 12au7 model in LT Spice?   When i tried it a few years ago there were no tube models at all in there.
j
DON'T PANIC
Sheldon
#35
I simulate a 12au7 triode stage quite correctly, but when I try to simulate your schematics there are a lot of gain attenuation and the output signal is far thinner as the input one when I try with a guitar wave input
samhay
From memory, the valve models I have tried with LTSpice don't give sensible results at low voltages.
Sheldon. What do you hope to learn from a simulation regarding Johan's design? Can you replace the triodes with e.g. BJTs to get a feel for what's going on?
Johan
A stupid thought, perhaps, but i have to point it out as i made that mistake myself..
..i drew the opamp +input at the top, and i think LT spice have them on the bottom of the opamp....?
J
DON'T PANIC
Sheldon
@Johan : I verified and the opamp I drew the opamp in lt spice as in your schematics
@samhay : In fact I'm quite a newbie in electronics (I had a few lessons when I was in engineering school but it's not my job) si I decided to simulate Teemuk, Johan... schematics with LT spice so I can try to understand part by part how they work!
samhay
#39
fair enough - it's a good general approach to understanding how these things work.
I found some old LTSpice simulations of circuits based on Johan's design. One is below - save the text as a .asc file and it should work once you add TL072 and 12au7 model files (.sub). The 12au7 model I used gives some gain with a 9V supply. I don't trust the amount of gain, but at least it shows it working.
Version 4
SHEET 1 4188 1712
WIRE 2304 272 2288 272
WIRE 2384 272 2368 272
WIRE 2752 320 2752 304
WIRE 2864 320 2864 304
WIRE 2288 352 2288 272
WIRE 2304 352 2288 352
WIRE 2384 352 2384 272
WIRE 2384 352 2368 352
WIRE 2496 400 2496 384
WIRE 2864 416 2864 400
WIRE 2944 416 2864 416
WIRE 2288 448 2288 352
WIRE 2288 448 2256 448
WIRE 2304 448 2288 448
WIRE 2384 448 2384 352
WIRE 2864 448 2864 416
WIRE 3200 464 3184 464
WIRE 3280 464 3264 464
WIRE 2496 496 2496 480
WIRE 2560 496 2496 496
WIRE 2672 496 2624 496
WIRE 2816 496 2672 496
WIRE 1760 512 1744 512
WIRE 1824 512 1760 512
WIRE 2496 512 2496 496
WIRE 1760 544 1760 512
WIRE 2288 544 2288 448
WIRE 2304 544 2288 544
WIRE 2384 560 2384 448
WIRE 2384 560 2368 560
WIRE 2432 560 2384 560
WIRE 2752 560 2752 400
WIRE 2976 560 2752 560
WIRE 3072 560 3040 560
WIRE 3184 560 3184 464
WIRE 3184 560 3152 560
WIRE 3200 560 3184 560
WIRE 3280 560 3280 464
WIRE 3312 560 3280 560
WIRE 3392 560 3376 560
WIRE 2000 576 1968 576
WIRE 2032 576 2000 576
WIRE 2192 576 2176 576
WIRE 2288 576 2192 576
WIRE 2304 576 2288 576
WIRE 2752 576 2752 560
WIRE 3392 576 3392 560
WIRE 2000 592 2000 576
WIRE 2192 608 2192 576
WIRE 2288 608 2288 576
WIRE 1664 624 1664 512
WIRE 1680 624 1664 624
WIRE 1760 624 1744 624
WIRE 1840 624 1760 624
WIRE 2496 624 2496 608
WIRE 2576 624 2496 624
WIRE 2672 624 2640 624
WIRE 2704 624 2672 624
WIRE 2496 640 2496 624
WIRE 2672 640 2672 624
WIRE 3520 656 3392 656
WIRE 3184 672 3184 560
WIRE 3200 672 3184 672
WIRE 3280 688 3280 560
WIRE 3280 688 3264 688
WIRE 1664 704 1664 624
WIRE 2000 704 2000 672
WIRE 2192 704 2192 672
WIRE 2288 704 2288 688
WIRE 2944 704 2944 416
WIRE 2976 704 2944 704
WIRE 3072 704 3040 704
WIRE 3168 704 3152 704
WIRE 3200 704 3168 704
WIRE 2720 720 2720 672
WIRE 2832 720 2832 544
WIRE 2832 720 2720 720
WIRE 2496 736 2496 720
WIRE 2672 736 2672 720
WIRE 2832 736 2832 720
WIRE 3168 736 3168 704
WIRE 3392 752 3392 736
WIRE 3168 832 3168 816
FLAG 1824 512 V+
FLAG 1664 704 0
FLAG 1968 576 IN
IOPIN 1968 576 In
FLAG 2000 704 0
FLAG 2336 528 V+
FLAG 3520 656 OUT
IOPIN 3520 656 Out
FLAG 2336 592 0
FLAG 2288 704 Vb
FLAG 2832 816 0
FLAG 2864 304 V+
FLAG 1760 704 0
FLAG 1840 624 Vb
FLAG 3232 656 V+
FLAG 3232 720 0
FLAG 2496 384 V+
FLAG 2672 576 0
FLAG 2672 736 0
FLAG 2752 304 V+
FLAG 3168 832 Vb
FLAG 2192 704 0
FLAG 2496 736 0
FLAG 3392 752 0
FLAG 2176 448 Vb
SYMBOL voltage 1760 512 R90
WINDOW 0 6 58 VBottom 2
WINDOW 3 8 56 VTop 2
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value 9
SYMBOL triode 2864 496 R0
SYMATTR InstName U2
SYMATTR Value 12AU7
SYMBOL voltage 2000 576 R0
WINDOW 0 -9 59 Left 2
WINDOW 3 -77 154 Invisible 2
SYMATTR InstName V2
SYMATTR Value SINE(0 0.3 300 5m 5 0 200)
SYMATTR Value2 AC 0.1 0
SYMBOL EuropeanCap 2096 560 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName C1
SYMATTR Value 100n
SYMBOL EuropeanResistor 2304 704 R180
WINDOW 0 31 76 Left 2
WINDOW 3 31 40 Left 2
SYMATTR InstName R3
SYMATTR Value 1Meg
SYMBOL EuropeanResistor 2816 720 R0
SYMATTR InstName R5
SYMATTR Value 1k
SYMBOL EuropeanResistor 2848 304 R0
SYMATTR InstName R6
SYMATTR Value 100k
SYMBOL EuropeanResistor 1744 640 M180
SYMATTR InstName R2
SYMATTR Value 10k
SYMBOL EuropeanResistor 1744 720 M180
SYMATTR InstName R4
SYMATTR Value 10k
SYMBOL EuropeanPolcap 1744 608 R90
SYMATTR InstName C3
SYMATTR Value 100µ
SYMBOL EuropeanCap 3376 544 R90
SYMATTR InstName C5
SYMATTR Value 1µ
SYMBOL opamp2 2336 496 R0
WINDOW 0 -28 63 Left 2
WINDOW 3 29 95 Left 2
SYMATTR InstName U1
SYMATTR Value TL072
SYMBOL opamp2 3232 624 R0
SYMATTR InstName U3
SYMATTR Value TL072
SYMBOL triode 2752 624 R0
SYMATTR InstName U4
SYMATTR Value 12AU7
SYMBOL npn 2432 512 R0
SYMATTR InstName Q1
SYMATTR Value BC337-25
SYMBOL EuropeanResistor 2512 496 R180
SYMATTR InstName R1
SYMATTR Value 1k
SYMBOL EuropeanResistor 2512 736 R180
SYMATTR InstName R7
SYMATTR Value 1k
SYMBOL EuropeanCap 2624 480 R90
SYMATTR InstName C4
SYMATTR Value 220n
SYMBOL EuropeanCap 2640 608 R90
SYMATTR InstName C6
SYMATTR Value 220n
SYMBOL EuropeanResistor 2688 592 R180
SYMATTR InstName R8
SYMATTR Value 10k
SYMBOL EuropeanResistor 2688 736 R180
SYMATTR InstName R9
SYMATTR Value 10k
SYMBOL EuropeanCap 3040 544 R90
SYMATTR InstName C2
SYMATTR Value 100n
SYMBOL EuropeanCap 3040 688 R90
SYMATTR InstName C7
SYMATTR Value 100n
SYMBOL EuropeanResistor 2736 304 R0
SYMATTR InstName R10
SYMATTR Value 100k
SYMBOL EuropeanResistor 3056 576 R270
WINDOW 0 27 56 VTop 2
WINDOW 3 5 56 VBottom 2
SYMATTR InstName R11
SYMATTR Value 100k
SYMBOL EuropeanResistor 3056 720 R270
SYMATTR InstName R13
SYMATTR Value 47k
SYMBOL EuropeanResistor 3152 720 R0
SYMATTR InstName R14
SYMATTR Value 47k
SYMBOL EuropeanResistor 2160 464 R270
SYMATTR InstName R15
SYMATTR Value 1k
SYMBOL EuropeanResistor 2288 464 R270
SYMATTR InstName R16
SYMATTR Value 1
SYMBOL EuropeanResistor 2080 592 R270
SYMATTR InstName R17
SYMATTR Value 33k
SYMBOL EuropeanCap 2208 672 R180
WINDOW 0 24 64 Left 2
WINDOW 3 24 4 Left 2
SYMATTR InstName C9
SYMATTR Value 220p
SYMBOL EuropeanCap 3264 448 R90
SYMATTR InstName C10
SYMATTR Value 100p
SYMBOL EuropeanResistor 3184 576 R270
SYMATTR InstName R12
SYMATTR Value 100k
SYMBOL diode 2304 368 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName D1
SYMATTR Value 1N4148
SYMBOL diode 2368 256 R90
SYMATTR InstName D2
SYMBOL EuropeanResistor 3376 640 R0
SYMATTR InstName R22
SYMATTR Value 10k
SYMBOL EuropeanResistor 3376 560 R0
SYMATTR InstName R23
SYMATTR Value 1
TEXT 1648 184 Left 2 !;.http://www.diystompboxes.com/smfforum/index.php?topic=107868.0\n;\n.tran 0 50m 0 1m\n;.ac oct 10 10 100000\n.lib usr/TL072.sub\n.lib usr/12AU7.sub\n;
