Trouble with my ultimate octave build
Started by copperheadroads, March 15, 2015, 08:52:13 AM
copperheadroads
I built an ultimate octave clone from a ready to populate pcb
used this pcb
http://shop.pedalparts.co.uk/FoxxTave/p ... 89291.aspx
layout & schematic is here
http://pedalparts.co.uk/docs/FoxxTave.pdf
I'm building the ultimate octave version .
the problem Is while it seems to work it is a very dark tone ,the tone knob seems to work in reverse though all 3 pots are same 100k ,but with it maxed (cclockwise) it is not overly bright & the fat/bright switch does nothing .
Volume & fuzz controls seems to work as they should, though volume maxed is no louder than bypassed & octave engaged does work .
checked all components for proper values & polarity of electrolytic caps & orientation of diodes & transistors .
reflowed all solder joints
When I originally tested the board i did not really take notice there was a problem so i wired it in the enclosure ,but i have removed it to do some debugging .
any suggestions ? diodes maybe
I've built a dozen or more pedals without much trouble ..this one bit me ....Thanks
well, copperhead, as we always say here, "welcome to the forum". we are then instructed to say "go here ..... "
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
" .... follow instructions, post results."
