A MOSFET powered Bazz Fuss :)
Started by mac, March 18, 2015, 08:30:11 PM
mac
In a recent post a I saw a schematic having a mosfet biased by a reverse diode.
The tiny leakage current of the diode is enough to turn the mosfet on because its gate needs a few electrons.
OTOH, in a well tuned Bazz Fuss (or Arsenio Novo distortion), the collector voltage Vc must be equal to the base voltage Vb. This is why a darlington BF sounds better than a 2n5088 or BC550, it needs a lot less current across the diode so Vc tends to Vb with a smaller collector resistor. A mosfet is similar to a darlington in this aspect.
Note:
I wrote about it and posted a circuit that it is in my gallery. If you use a simple transistor, add a big resistor at the base and tweak the collector resistor to find the sweet spot.
For example, if you have hfe=100, Rb=1M the tuning condition Vc=Vb gives,
ic*Rc = ib*Rb =ib*hfe*Rc,
Rc = Rb/hfe = 1M/100 = 10k  :)
And yes, the tuning condition depends on temperature  >:(
So, what if I replace a darlington with a mosfet?
I went to the breadboard, picked a BS170 and it worked fine, much like the darlington version.
But you need a pair of back to back diodes, silicons or leds.
I also used a 100k at the drain with a small change in sound.
If you want a kind of gain control you can add a drain to gate resistor of some mega ohms or less, and/or a source resistor, variable or wired as in a Fuzz Face.
I ran a simulation with an input cap a bit high for my taste, and a power mosfet model. It might roll off more highs than a BS170.
This is the circuit, including a simple guitar mic and cable capacitance.
And the output signal,
Enjoy.
mac
Your images do not show. When I access the URL directly I hit a Microsoft log-in.
Use imgur.com or other public host.
mac
#2
I uploaded the files in a private folder in OneDrive, moved them to a public folder and modified the post  :icon_redface:
Can you see them now? I can in incognito mode after logging out and closing outlook.
BTW, I can't upload in the Layouts Gallery, I get *error 7*, can't write to disk.
mac
bool
Still no-show from your pictures. But yes, a BF mosfet derivative definitely works.
antonis
Am I the only one who sees the pictures..??? ???
(but I can't see any distortion - perhaps because of the 250mV input sin..)
mac
I see everything twice!
why the 0.001 for Rs?
there is a "can't post to gallery" thread, aron say it's full.
ggedamed
Quote from: duck_arse on March 19, 2015, 10:10:14 AM[...]
I think the sim chokes when the resistance is 0.
Minds are like parachutes. They only function when they are open. (Sir James Dewar, Scientist, 1877-1925)
mac
Quotewhy the 0.001 for Rs?
QuoteI think the sim chokes when the resistance is 0.
LTSpice doesn't like 0 resistance.
But the purpose of Rs is to control gain. I ran simulations with different values of Rs.
As I said in the first post, you can put a 2.5K or 5k pot there wired as a variable resistor.
Quote(but I can't see any distortion - perhaps because of the 250mV input sin..)
The input signal is limited and rounded by the diodes. The output looks *like* a sine wave but it is not, it's been distorted, even though the 250mV of the voltage source drops 90% at the *in* node.
mac
mac
antonis
Quote from: mac on March 19, 2015, 12:51:53 PM
O.K. -  although your screen is at 1mS interval..
(at 500μS or better at 250μS it should be more "realistic"..)
midwayfair
You can also put a MOSFET in there instead of the two diodes -- this makes it more asymmetrical like the original Bazz Fuss, but not quite as insanely so. :)
