Pivoting - Changing Course Mid-Design
Started by Bill Mountain, April 16, 2015, 09:37:20 AM
Bill Mountain
I've been using this term a lot lately for when I hit a road block and need to change course.
I built a bass fuzz that I have spent an absurd amount of time on.  I plugged it into my rig at practice and promptly blew my speakers.
At first I was really let down.  After an objective review of the circuit there was too much subsonic low end and the voice coils in my cab just melted instantly.  I spent so much time making it bassy that I forgot to make sure it was safe and that I could hear it in the mix.
So...after the minimum standard moping period I decided to Pivot.  I removed the the bass heavy clipping stage.  Added more high mids to an earlier stage. Lowered the gain. And now I have a pretty killer trebly overdrive.
It's not what I set out to build but it'll actually work out better than the speaker killer.
So...any similar stories?  Something you changed mid-design that turned out way better?
blackieNYC
I set out to make a Jordan Bosstone.  Exhibiting no knack for self-restraint again, I put a mosfet booster in front of it.  then I decided I need a notch filter in between.  Some filter.  I don't remember because I lost the schematic.  This was last fall.  I couldn't commit to a few trim pot settings, so there are two drive pots, a center freq pot, a god-knows-what pot, and an output volume.  And a diode insert switch.  ( I think the Bosstone has 1 or two knobs)
At first I thought it was great, but then I noticed some awful low frequency farts, when all gains and drives were cranked.  To look at them more closely, I boosted the thing more, with a fuzz face in front.  The farts, if you hold one note, turned out to be bursts of one octave down, alternating with a distinct 5th (!) one and a half octaves down.  One held note would jump around by octaves and fifths about every 1 or 2 seconds.  The frequency knob determines where on the neck the intervals pop out most.
Five knobs and a toggle, and most modes of the pedal didn't end up to be what I wanted, other than one particular setting that has a gnarly punkabilly twang.  Some kind of severe notch.
So now - I'm going to get rid of all the pots with fixed resistors, add more front end boost, and have the pedal do just... two... things:  Punkabilly overdrive, and the awesome interval-skipper fuzz.   One toggle, one volume knob, one freq knob  I've got to stop being afraid of one(or two)-trick-pony pedals.  I've got to stop adding feature after feature.  I have so many pedals, they all don't need to do everything.  Look at that thing in my profile picture over at the left.  My first pedal.  Ridiculous.
CodeMonk
Quote from: blackieNYC on April 16, 2015, 11:10:53 PM
That sounds kinda freaky.
Any chance of a clip?
DougH
I think there are some write-ups on here somewhere about the Bosstone doing that octave thing with the correct choice of input capacitor.
CodeMonk
Quote from: DougH on April 17, 2015, 08:43:05 AM
Input AND Output cap value x 10 or so.
But if you let the cap values get to far apart from each other, it gets kinda ugly.
blackieNYC
#5
http://www.diystompboxes.com/smfforum/index.php?topic=109392.0
This was my thread from a little while ago.  Got a lot of help, but I didn't get anywhere. Mine is more than a bosstone - I have a booster and some kind of eq in front of the bosstone.  Ill get back to that thread when I finish modding that thing.
Point is, if the pedal gives you lemons, make whiskey sours.  Like the OP.  Good post - who's got another Pivot?
"If at first you don't succeed - try, try again.  Then quit. No point being a damn fool about it."  WC Fields
Blitz Krieg
more speaker melting circuits please...
