BTDR3 verb
Started by Kipper4, April 21, 2015, 11:51:04 AM
I'm losing my marbles or my data. I'm not sure which.
I thought i had a schematic for a reverb with the brick3 but I cant find it in my files or on google.
Now where did I see that please help.
Tired and weary Rich
Fender3D
You may use any BTDR2 schematic, just add a dual 10K (or 100K  :icon_wink: )@ pins 7-8 and 9-10
mth5044
1776 has a project that used it. I tried it out and it's not bad.
Yer I found that one thanks Myth.
I guess the dwell (feedback loop) i not needed since twin pot decay deals with this.
I saw that you made use of the 100k in your parallel drive verb project mate.
Did you build it and how did that work out?
I wanted to get working on a basic schematic and diylc layout tonight but the motivation is just not there.
I'll get that sorted by the end of week. Meantime anyone who has used the brick3 feel free to chime in with opinions and such.
Cheers
mth5044
I forgot to update that thread. It worked perfectly.
Not sure about what feedback you are talking about. For both the 1776 and the circuit I made off of it, the reverb signal is only fed back internally (probably). The output of the brick goes right to the mixing section with the opamp, no feed back needed.
Yerrrr Sorry Myth I was refering to te dwell pot seen in the All star Reverb.
You cleared that up for me to, nice one geezer.
Carry on.
edit; Layout is now done based on the 1776effects schematic, while I still have the brick off board I'll breadboard the parallel drive/verb.
mth5044
Ah ok, got it!
Good luck with the breadboard. You can really put anything in place of the tube screamer. A simple boost might be easiest for a proof of concept.
