6.3mm socket EAGLE part
Started by crane, April 22, 2015, 10:55:45 AM
crane
Sorry for kind a stupid topic, BUT I 've searched and searched and I cannot find any 6.3mm socket parts in EAGLE - neither in software nor on the web. I know that we are supposed to draw our own parts it's just that a 6.3mm socket seemed such a common thing...
karbomusic
Quote from: crane on April 22, 2015, 10:55:45 AM
I know that we are supposed to draw our own parts...
I wish I knew how. :) In the meantime you could always manually place pads with proper spacing.
armdnrdy
It depends on the manufacturer....
Look in gm-jacks.lbr....stereo switched jack. The package will fit the neutrik footprint.
If you have Chinese knock offs (Tayda and the like)....the size varies. I've had to modify the GM package to create a package that works for the knock offs.
Best to print out the package to see if your jack's pin line up with the eagle part.
crane
Thanks armdnrdy - I will check that library.
karbomusic - please don't consider this a rude answer but google and youtube really are your friends at this - there really are good tutorials :)
electrosonic
#4
There is something similar in the gm library.
Look here - http://gaussmarkov.net/wordpress/tools/software/eagle-cad/
There is an updated version of this library shared by madbean on his forum - you could look for that.
Get the data sheet - I think it is this.
Check the hole size and spacing (I think the hole sizes are too small in the gm version) and edit as needed.
Andrew.
karbomusic
#5
Quote from: crane on April 22, 2015, 11:24:28 AM
I don't consider it rude at all, the last tutorial I saw seemed way more complex than I felt like going through for the simple part I needed at the time. I'm not the type to wait for it to fall in my lap though, if I really wanted to build one badly, I'd hunker down and figure it out.  :icon_lol:
~arph
Madbean has a library too, they are in there as well. Or search for neutrik. Eagle has a pretty bad search mechanism. It needs exact matches.
karbomusic
Quote from: ~arph on April 22, 2015, 04:15:45 PM
Or asterisks on both sides of the term if you have any idea what the term is.
~arph
Really? Cool did not know that!  That is really useful as i dont have to remember the part suffix
trixdropd
My gift to you guys. https://dl.dropboxusercontent.com/u/970384/Champion-Jacks1.lbr
Neutrik M Jacks are there,
Kobicon DC9v
Amphenol Stack jacks ect
The madbean Library is good but you should avoid the GM library as most of the pad holes are too small and you will likely have errors.
armdnrdy
#10
Quote from: trixdropd on April 23, 2015, 02:17:03 PM
There is something wrong with the link. It's not an Eagle library...it's code.
Open Eagle libraries, right click on the Jack library, hit copy, save on your desk top, put that library file in dropbox.
ggedamed
Works for me in Eagle 6.6.0.
Minds are like parachutes. They only function when they are open. (Sir James Dewar, Scientist, 1877-1925)
armdnrdy
Quote from: ggedamed on April 23, 2015, 02:52:35 PM
Aah...I have an older "free" professional version.  :icon_wink:
~arph
From version five. On they switched to an XML based system. So other parties can read/write the eagle format. It's pretty cool. All the drawing instructions are in there too. I once did a JavaScript parser for schematics and boards and got to about 90% rendering in the browser
crane
thank you all for the input.
gm library and champ library are both great :)
trixdropd
Quote from: crane on April 23, 2015, 04:15:07 PM
Watch those GM ones though, the hole sizes and pad sizes are many times wrong...
electrosonic
#16
Yes the gm libraries need to be double checked - I would recommend verifying all parts the first time you use them. For example the 5 volt regulator in the gm library has reversed the input and output pins - which has tripped me up (twice!)
I hate to criticize the gm libraries - they were the first eagle libraries customized for pedal builders and got many started using eagle.
That said, if I was just starting out I would skip the gm libraries and get the madbean libraries.
Andrew.
