Tisdale Buffer
Started by karbomusic, April 24, 2015, 09:29:18 AM
karbomusic
#20
Quote from: anotherjim on April 24, 2015, 03:45:49 PM
Neat work.
May I ask why the name "Tisdale"?
Well..... It was originally a four output buffer which would have been quadra something. Then, I added impedance selection, then I wanted polarity reversal but that needed a buffer in front to work properly, so I ditched one output and used that freed up channel provide the input buffer which turned into...
Triple
Impedance
Selectable
It was the best I could do at 3:00 AM when I went that route LOL or TISdale
mth5044
Dang, here I thought it was Nurse Tisdale from Scrubs.
Tony Forestiere
karbomusic
Can't call it done until it's actually done and now it is. Ran a few tests splitting off to multiple amps/DAW etc. All is well in buffer land; polarity switches and impedance selector work great. (whew)
blackieNYC
Very simple polarity flipper!
