A couple questions before my first assembly.
Started by suncrush, May 05, 2015, 08:47:31 AM
suncrush
Grounding
I know lots of people ground to the I/O jacks, but that's not quite going to work for me.  I have insulated jacks, and the folks at mammoth sprayed the inside of the box at the I/O jack holes when they were painting, so there's not really a good connection there anyway.  Can I just solder a ground line to a clean spot on the inside of the enclosure?  There's a good place available at the bottom of the box.
Stripboard
With 4 inputs from power, and 8 grounds, I think the best bet is to use a power input stripboard, and a ground stripboard.  What's the best way to hold the stripboard in place in the enclosure?  Epoxy?
DC Jack
I have a handy diagram on wiring the DC jack.  I see one of the ports is for soldering the positive lead of the battery adapter.  I'm not installing a battery.  Can I just ignore that connector?
bloxstompboxes
You might try soldering the gnd to the back of one of your pots. I see some people doing that. I never tried it but I doubt that the enclosure itself will take the solder if you tried soldering to it. Worth a try I guess.
Yes you can leave the terminal on the jack for the battery alone if you are not using one.
suncrush
Yeah, I looked it up, and soldering to aluminum is a pain.  I could solder to the pot, or I could solder to the washer on the mounting screw for the tube socket.  I feel like the pot is a better plan.
If you have a large-diameter knob, you might be able to add a countersunk screw under the skirt of the knob with star washers to bite into the chassis for a decent ground.  My Cort guitar used grounds to the back of the pots and an aluminum strip to connect all three pots together.  It went noisy after a while, so I added proper ground connections and now it sounds good.  (Page 16 on the guitar pictures thread.)
antonis
#4
Quote from: amptramp on May 05, 2015, 09:50:12 AM
One of my favorite methods for a really "stiff" grounding..!! :icon_wink:
(which also applies to any surface with decals over the screw..)
It requires a little care - especially for thin wall enclosures - if you'll use a commercial drill bit because the bit's point angle may not be the same with screw's head chamfer angle and you'll have to use a bit size a little biger than screw's head outer diameter, e.g. a 5 - 5.5 mm bit  for a 4 mm screw head and also press & turn the screw, without fasten it,  a couple of times to form an even and plane mold for perfect contact...
(or use an apropriate fluted countersink cutter on a GOOD drill chuck..)
GibsonGM
^  IMO, this is the best way to do it.  2nd best is to let the input jack ground to the chassis.  I don't get into soldering on the back of pots as they eventually seem to come loose, making that ground noisy or non-existent.
Jacks, with a star washer, seem to not do that to me.  You are always turning the pot...the jack isn't handled as much...
suncrush
Grounding to the LED bezel seems to be a reasonable solution.
bloxstompboxes
That's not a bad idea and not one I had heard of. As long as you use a star washer to really bite into the chassis and maybe a lock washer or some locktite to keep the nut from coming loose over time.
suncrush
Thanks a bunch for the assist on the grounding.  Does anyone have any advice on securing the small bits of stripboard?
Quote from: suncrush on May 05, 2015, 03:48:08 PM
Quote from: bloxstompboxes on May 05, 2015, 03:54:00 PM
And as long as the bezel is metal and allows you to really torque the nut down tight.
You might try a one of the 3M auto trim double sided foam tapes to hold the small piece of strip board to the enclosure.
