Penneyroyal Chorus not right...
Started by Luke51411, May 14, 2015, 10:45:05 AM
Luke51411
My stomptown pennyroyal chorus is not right. It is based on a small clone. It is warbling and not giving a terribly deep chorus sound almost like the mix of dry to affected signal is off or the lfo is uneven. I've tried fine tuning the bias but no luck. Build doc http://nebula.wsimg.com/bdd4ad9af1f6c30bce362f816df64a03?AccessKeyId=9565C586FCFADE7D9863&disposition=0&alloworigin=1
At high speed and depth it sounds sort of metallic ring modish type sound Voltages are as follows
Ic1
1 4.42
2-4.42
3-4.32
4-0.004
5-4.4
6-4.4
7-4.4
8-8.8
Ic2
1-1.5 to 1.9 variable
2-4
3-4
4-.004
5-1.9 to 2.5
6-2.195
7-2.7 to 3.7
8-8.83
Ic3
1-8.1
2-4
3-4
4-.005
5-.004
6-4.06
7-4.25
8-4.25
Ic4
1-8
2-.092
3-6.9
4-8.15
5-8.15
6-8.15
7-.004
8-.004
9-.004
10-4
11-4
12-.003
13-8.03
14-8.15
Q1-
E-3.5
B-2.9
C-0
Q2
E-3.5
B-4.11
C-8.1
Q3
E-8.15
B-8.79
C-8.84
mcknib
Alrite Luke,
Here's my readings from a similar build for reference i.e small clone (I'm sure you can guess where I got it from!) At a glance there are some differences on the LM358 especially pin 7 and pin 9 of the CD4047
Supply 9.03v
IC1 4558
1.   4.3
2.   4.3
3.   4.2
4.   0
5.   4.3
6.   4.3
7.   4.3
8.   8.7
IC2 MN3007
1.   8.05
2.   4
3.   4.4
4.   0
5.   0
6.   3.98
7.   4.43
8.   4.43
IC3 4047
1.   7.16
2.   0.06
3.   6.93 -7.17
4.   8.06
5.   8.04
6.   8.04
7.   0
8.   0
9.   4
10.   4
11.   4
12.   0
13.   7.92
14.   8.05
IC4 LM358
1.   0.8 to 2.5
2.   3.94
3.   3.91
4.   0
5.   0.89 to 3.4
6.   2.13
7.   0.01 to 7.4
8.   8.71
Q1 E. 3.86  B 3.22  C 0
Q2 E 3.72  B 4.28  C 8.7
Q3 E 8.04  B 8.67  C 8.7
I'll have a look over your images when I get a chance hopefully you'll have it sorted by then I'm just off out
R30 looks like it might be 4K7 (yellow, purple, black, brown, brown.) not 47K (yellow, purple, black, red, brown) can't really see if the 2nd last band is brown or red. Can't see R8 but all the rest as far as I can see are the correct values all polarity looks correct for electros, diodes, IC's.
