What Did I do...
Started by Switchfooter, May 16, 2015, 10:40:21 AM
Switchfooter
Hi y'all,
I've been meaning to make an account here for a long time, so I figured now is a good time. I'm having problems with a Boss SD-1 overdrive I re-housed. At first, it was stuck on, but I figured out that I needed to insulate the raised strip that runs around the bottom plate of the enclosure. After that, it works as it should, but when the effect is off the LED still has a faint glow. Did I short something out?
Thanks,
-Tyler
Hope I posted in the right place  :)
darron
Did you replace the LED for a different one? I THINK I did that and had a similar problem years ago on a HM-2 when I replaced the regular 3mm red LED for a super-bright clear one. The difference I assume is that it relies on a specific forward voltage drop.
If someone else could jump in and confirm...
Switchfooter
Quote from: darron on May 19, 2015, 11:55:54 AM
Yeah, I changed the 3mm one for a 5mm
darron
if you want to keep that mod I'd be looking at replace D2. It's a 5V1 zener by the look of it. At a guess, maybe try 6V2? Assuming it's only on very dim and faint while in bypass that is.
Yes, it does.
The old-old LEDs were less bright and we never noticed. A new LED is much brighter for small currents so now we can see it.
If it is not a problem, ignore the glow.
If it really bugs you, try a 22K or 10K resistor directly across the LED.
Switchfooter
Quote from: PRR on May 24, 2015, 02:41:08 PM
Yes, it does.
So just solder a resistor to both legs of the led?
Or replace the 3k9 resistor (R30) with a higher value, like 10k or 15k, depending on the brightness of the LED and the desired brightness.
Govmnt_Lacky
When you re-housed the circuit, did you make it true bypass? Did you carry over the diode and resistor between the LED and power?
There is a well known mod for Boss pedals when NOT using the ACA power supplies. Google it  ;D
