BSIAB II help
Started by njkmonty, May 26, 2015, 05:31:10 AM
njkmonty
Ive recently built a Bsiab 2
http://gaussmarkov.net/wordpress/circuits/brown-sound-in-a-box-ii-bsiab2/
Its squealed like buggery on highest gain settings, i used shielded cable , everything, no change,
then I put a 33K resistor from effects input to Ground.
It then removed all squeals and still had all treble available.
Is this ok to do?
is there a logical reason why this happened?
GibsonGM
If it works, it's fine :)  Not causing any odd tonal issues, then I would not worry about it.
What is happening is that you are experiencing oscillation due to (probably) lead dress or insufficient power supply decoupling.  There is a capacitance associated with your first gain stage (all gain stages, in fact, it's called the Miller effect)...with the input impedance, you form a resonant circuit that 'keeps the power going around the loop' - a feedback loop.  Usually you try to get rid of the parasitics (improperly run leads etc) rather than add parts, but...
Your R changed the resonant frequency enough to stop the loop.
The only odd thing I see is that the 1M already there should do the job of the 33k you added...so, all R's/Z's in parallel must have changed by just enough with your 33k to do the job.
I expect ALL high gain circuits to squeal at high settings - it's part of the territory.  But if you found a quick hack to limit it that works, and doesn't bother you, power to ya!  :)
