Transformer Isolated Splitter Power Question
Started by canman, June 01, 2015, 10:46:14 AM
canman
I've been looking at building this for a while now after someone mentioned it a few weeks ago:
I don't want to use two batteries to run this thing though.  Would it be possible to use this:
And just use +9v and -9v from this inverter and apply it to the transformer isolated splitter?  Or is this considered bad practice and not a good idea?  Oh also...is that just a single opamp being used in the splitter?
mth5044
The voltage inverter is a very typical of getting a bipolar supply in this little pedal world, and should work for you here.
Based on the pin configuration of the opamp, it looks to be a TL071, with pin 3 being the positive and pin 2 being the negative inputs. I imagine you could use a TL072 or a handful of other opamps without a problem.
canman
