Shielding a breadboard?
Started by MrBinns, June 11, 2015, 02:45:15 AM
MrBinns
Are there any ways besides sticking everything in a grounded metal box?
graemestrat
Hi,
One trick I do often is place the breadboard on top of a sheet of aluminum and ground it to your circuit ground.
it is probably not perfect but it does reduce the noise a lot, especially with high gain circuits.
Cheers
antonis
#2
It's better to wrap the board with a bigger aluminum foil, taking care of undesirable short circuits..
(which also is a good precaution for static discharge sensitive devices during populating the board..)
LightSoundGeometry
I am inspired to build another tube amp turret style pedal now lol
MrBinns
>turret style
o wow that's cool
http://www.versoul.com/images/amp/amp_oheiskomp.jpg
Thanks for the tips. I'll try the aluminium foil.
Jarno
Not breadboard, but a colleague of mine is going to have a run of perf board made, with a groundplane. Apparently pretty expensive to buy from places like RS and Mouser.
You keep the ground plane on top to prevent shorts :-)
LightSoundGeometry
I been working on one for a while now
Cozybuilder
I have to ask-
Is your Super Hard On working?
Put the breadboard inside a microwave oven and close the door.  You can usually get a microwave oven at a garage sale for $10 so there is no reason to try more expensive and temporary items such as aluminum foil.  The shielding is good for microwave frequencies but may leave something to be desired at lower frequencies.  DO NOT PLUG THE MICOWAVE OVEN IN AND TURN IT ON.  It gets too entertaining that way.
GibsonGM
#9
^^^   NO! That won't work - it's too high tech.  Since we're working below 20kHz, it won't be able to recognize what we're doing.
Put the breadboard in a metal BREAD BOX.  After all, THAT IS WHAT IT IS FOR.  Ground the box.  You are now shielded.  Add in/out jacks and a bypass switch, and make it a regular thing.
I'm not sure if a metal MILK BOX will work - I think I read on another forum that it caused some kind of issues...time to go hook up a new SHO on mine...  :)
LightSoundGeometry
Quote from: Cozybuilder on June 12, 2015, 05:42:37 AM
I have to ask-
the biological one yes, the mechanical one not so much lol
it may of just needed shielded - open turret + gain pedals not good lots of noise :)
antonis
Quote from: amptramp on June 12, 2015, 10:04:13 AM
Not even if there are some BIG electrolytic caps on the board..??
