The Sidescroller Fuzz - Insane 8-bit sounding fuzz
Started by Freppo, June 16, 2015, 08:24:13 AM
Juppstein
Quote from: Freppo on July 12, 2015, 07:54:15 PM
Hi Juppstein. Thank for the build report. I'm glad you have found an interest for my stuff. :)
I'm sorry to say that it sounds like you may have a problem with your vero build though.  :-\
You should check the values of the components around the LFO section and the diode orientations.
I already found 47k resistors in place instead of 470k ones  :icon_confused: heaven knows I should stop sniffing solder fumes..... It is still not how it should be but given that awful mistake with the 470k'ers I wouldn't be surprised to find other horrid mistakes. But I'll work it out, eventually  :icon_rolleyes:
Freppo
Quote from: Juppstein on July 19, 2015, 09:21:43 AM
Ahh, those 47K resistor would explain your problems.
It will keep the pulsewidth narrow, not allowing the modulation to make it wider.
Glad you found a mistake, means you are on the right track :)
Check out my building blog at www.parasitstudio.se
