Boss JFET
Started by spoontex, June 30, 2015, 07:04:36 AM
spoontex
Hello,
anyone can help me to found the input and output jfet buffers from these pedals? I want it convert to truebypass and I would remove these transistors.
Boss BD-2
Boss CS-3
Thanks!!
GibsonGM
Psst!  Welcome to the forum...can you post the schematics for them so ppl don't have to go hunt them down?  ;)
You'll have an answer for sure, I think Boss was pretty consistent so just check back once in a while.
Meantime read this:  http://www.geofex.com/Article_Folders/bosstech.pdf
JerS
Check out the instructions for adding clickless true bypass from Mammoth Electronics - they tell you what you need to do to defeat the fet flip flop circuit in Boss Pedals. Here is the link: http://www.mammothelectronics.com/v/vspfiles/assets/images/clicklesstruebypasscatalog.allsections.interactive.2013-1.pdf
I would think you could use this to help guide you in converting to true bypass.
spoontex
What you mean?
removing this resistor it's enough to disable the buffer?
I understand that removing this resistor the effect will stay alway on, but through the in/out buffers anyway.... no?
Boss BD-2 : http://www.freeinfosociety.com/electronics/schemview.php?id=116
Boss CS-3 : http://i2.wp.com/pdfelectronics.com/wp-content/gallery/pedal-mods/boss-cs-3-schematic.jpg?
I see this post: http://www.diystompboxes.com/smfforum/index.php?topic=61035.0
And I want make the same with the BD-2 and CS-3. If removing one resistor it's enough, because they don't remove it and let the transistor on the board?!?!
thanks.
GibsonGM
Is there a reason you don't want the buffers?  They really don't affect much, if anything at all.  You are correct, that way the buffer is still in the circuit.  You'll have to read more to find out if there is an easy way to jumper the buffer.
But, so you know...look for the last "Q" before the output. That is your buffer.  The switching circuit is a flip-flop, so follow its right hand output.
Anybody ever hear of Blind Urge to Mod Syndrome (BUMS).    :icon_lol:
(1) true bypass isn't the panacea that it's promoted as; there are certain very special instances where it's a good idea, but these situations don't happen much any more in today's world
(2) there are simpler ways to true bypass a Boss pedal that do not involve as much surgery; notably, you can simply use the existing flipflop circuit to run a relay inside the box; see the Technology of Boss and Ibanez Bypasses http://geofex.com/Article_Folders/bosstech.pdf at geofex.com http://www.geofex.com.
In fact, reading all of geofex.com would be a GREAT idea for any beginner.
