BYOC Brown face harmonic tremolo - 12V?
Started by patricks, October 09, 2023, 06:00:27 AM
patricks
Howdy all!
I'm planning on using part of the BYOC Brown face harmonic trem as a building block in a circuit I'm working on at the moment, the schematic is here, and the part I'm most interested in is the high and low band gain stages around Q2 and Q3.
Would it be okay to simply supply it with 12V, or should I change the resistor values?
Thanks heaps
Pat
antonis
Q2 & Q3 Collectors should be biased at a higher level (about +25%) but as long as both are biased at the same level, it shouldn't be a problem..   :icon_wink:
patricks
Brilliant, thank you 🙂
Would the simplest way to do that be to decrease the value of R8 and R9 a bit?
antonis
Nahhh..
(never count on hFE for bias..)
edit: I didn't say above you MUST bias them higher..!! :icon_wink:
(they WILL be biased higher due to higher supply voltage..)
patricks
Ah, I thought so - my first step was just going to be to connect them to 12V when setting the circuit up on the breadboard and see how it goes :)
antonis
