Diodes in ground leg?
Started by PBE6, July 14, 2015, 02:47:25 AM
PBE6
Just had a wacky idea about putting diodes in the ground leg of a non-inverting opamp and wondering if it serves any useful purpose. I was going to breadboard it, but it's too late for me to be making noise at the moment so it'll have to wait until tomorrow.
The starting point for my idea was a circuit like this:
With one diode in the ground leg only half the waveform would be affected, so it's probably best done with a diode pair instead.
The total current through the forward-biased ground leg diode will be:
iD = vin / (RD + Rg) = vin / (vD/iD + Rg) = (vin - vD) / Rg
For small signals the diode doesn't conduct much and the diode resistance is very high, so the circuit acts like a buffer. As the signal gets bigger, the diode begins to conduct more and the diode resistance decreases dramatically. This has the effect of ramping up the gain very high for signals above a certain threshold. In some sense this is akin to an expander because it increases the dynamic range of the signal. It will actually increase the signal a bit too much with certain resistor pairs, so I'm thinking that clipping diodes (either in the feedback loop a la the Tubescreamer or straight to ground a la the MXR Dist+) are a must.
Anyhoo, I tried simulating the Tubescreamer-esque variant and it makes a neat shape:
As you can see it follows the larger signal for a portion of the cycle before shooting up past a certain threshold. It looks like a Tubescreamer waveform (shown below) except more pinched:
As I said I haven't tried this out in real life yet so I don't know how it sounds, but it looked cool so I thought I'd share.
Anyone else tried diodes in the ground leg before? Useful or useless?
You need to add a discharge path on the cap using say a resistor, otherwise it will just stay charged.
what waveform if you add a normal R//C leg in parallel to the diode leg?
PBE6
@duck_arse it depends a bit on the resistor values, for Rg2 close to Rg1 it looks pretty much like a Tubescreamer:
For Rg2 much smaller, it gets a bit mangled and shifted (though I'm sure a large part is due to filtering alone):
PBE6
Thanks teemuk, I will take a closer look tonight! Dumb question, what's a good DIY Stompboxes analogue for a current source?
samhay
In my experience, it is best to put a resistor in parallel with the diodes. Also, you need to hit the input of the op-amp with a fairly hot signal to get any effect. In the end, I didn't find it very musical, but best results were with Schottky diodes and a boost in front.
