Fuzz Face - Debugging
Started by mikelambresi, July 30, 2015, 03:08:50 PM
mcknib
I think the ceramics for higher frequencies and the electro for lower
http://www.capacitorguide.com/coupling-and-decoupling/
mikelambresi
Got it, many thanks! useful info
mikelambresi
Hey everyone.
So I've been trying to use a couple of BC183L because I still find the BC108 a bit harsh, but they never worked.
I emailed the supplier because I suspected the provided pinout was wrong, and it turns out I was right!!(BCE instead of CBE).
I found 2 matching transistors with a gain of 140(the BC108 were 250) and now it sounds far better!!
I ended up biasing it around 4V.
Do you guys use the fuzz face on top of a clean, mild overdrive, or fully distorted amp? Just curious.
mikelam -  the L suffix added to any BC series part number means funny pinout. but you'd check the manufacturer's datasheet anyway, wouldn't you?
mikelambresi
duck_arse I did check but the datasheet the supplier provided was wrong. I contacted them, they tested it and confirmed it.
