Boss (digital) pedal troubleshooting help
Started by swinginguitar, August 06, 2015, 04:12:33 PM
swinginguitar
I have a PS5 that won't come on - when i first powered up i heard some static in in the line, then nothing. Same result whether on battery or AC adapter.
I haven't fully pulled it apart yet, but i did open up and at a glance haven't found the 5v regulator to check the digital supply rail.
I did check continuity on the switch - seems to be ok. So i'm thinking it's maybe a power issue (hopefully not a bad IC).
Anyone have any experience or insight to share before i dive in? Where are the regulators typically located on these devices? What are the odds i would be able to replace it (assuming SMD)? What else....filter caps? diodes?
Ice-9
Here is a picture of the pcb if it is of any help.
http://mirosol.kapsi.fi/wp-content/uploads/2014/07/Boss-PS5-guts2.jpg
The area around the bottom right looks like it will be the digital psu section with a few big caps, inductors and regulators.
www.stanleyfx.co.uk
swinginguitar
thanks! if i need to replace the VR, what are the odds i can manage a TO220 type 7805 on there?
