Need some help true bypassing a Russian Bass Balls
Started by skullservant, August 12, 2015, 08:55:39 PM
skullservant
Hey guys, I am trying to true bypass a Black Russian Bass Balls.
I really just need to know if any traces need to be cut, as well as where the effect input and output leads are on the PCB along with the jack input and outputs so that I can finish up wiring this 3PDT switch.
Any help would be appreciated!
aron
skullservant
I actually got it! I should leave it here for reference for future users.
I followed the layout for converting a Russian BMP to true bypass for the input and effect input. Then for the output I just traced the board to find the wire to the output jack. Then the effect output is a lead near the center of the board next to a resistor
aron
