ACE tremolo - Adventures with a Magnatone-inspired headphone amp
Started by samhay, August 18, 2015, 07:05:33 AM
samhay
Having been seduced by Martin Simpson's recent use of a stereo Magnatone amp (https://www.youtube.com/watch?v=I-ecWcnz8Tk), I thought I would have another look at the Magnavibe. As with the amp, it sounds better in stereo with the 2 channels driven with LFOs that are 180 degrees out of phase - hence my experiments with anti-correlated LFOs.
The only stereo guitar rig I have is a pair of headphones, so I moved on to using op-amp phase shifters that can do double duty as headphone amplifiers (note the over-sized C11 and C12). NE5532s can quite happily drive most headphones and it doesn't seem to need to be anything more than unity gain. I figure this can sit at the end of my pedal board and do double duty as a mono effect and stereo headphone amp.
The Tremolo control is equivalent to a dry mix control and fully CCW you get a high pass filter with the corner frequency swept up through the audio band - a tremolo of sorts. With the tremolo control CW you get a 180 degree phase shift like the Magnavibe.
The LFO is the Magnavibe PSO with a couple of single-supply op-amps working as LED drivers and phase inverters. The depth control works like a buffered version of that from the Tremulus Lune and the op-amp must be able to tolerate input at ground. The LFO / LED driver works, but is not perfect and I think I will have a play with a PIC implementation before I commit to building it.
Schematic (view for larger version):
Sound clip (recorded direct, probably best with headphones):
https://dl.dropboxusercontent.com/u/11996927/ACE_tremolo.mp3
Dry (Depth at 0) then Tremolo CCW and phase shift off - i.e. LFOs in phase. This is followed by phase shift on (LFOs out of phase) and Tremolo incremented to CW. Depth and Speed changes should be fairly obvious.
samhay
Thanks Rich.
I realised I hadn't decried the clip properly - the first part is with the LFOs in phase via the Phase Invert switch and I have updated the description in the post.
The option of playing with the the phase of the two LFOs is quite nice and I am planning on playing with a dual LFO PIC where you can vary the relative phase of the 2 LFOs. It's weird though, once you have been playing in stereo with the LFOs anti-phase for a while you stop hearing it. It comes back once you have rested for a while - amazing what ones brain can get used to.
blackieNYC
I won't be able to listen for a while, but isn't the right channel going to get a squarer waveform than the left?  Due to those 220k s?
Very cool.  Have you considered recombining to mono, perhaps with different filtering?  Or, I wonder what it would sound like now, in inverted L phase mode and mono?  Maybe not much, but it must do something a little interesting.
I have a (insert name of any commercial pedal here)Boss tremolo with stereo in and out that I love so much I want to replace it with something I built.  Like this.
samhay
IC2B has a gain of +1 or -1. It works like this:
http://www.geofex.com/article_folders/polarity_reverser/polarity_reverser.htm
The difference is that there is a BFC (C16) that allows the DC offset found on the non-inverting input to be maintained. The 10M resistor is a pull-down resistor to stop the BFC from popping and can be considered an open circuit.
I have thought about adding a mono/stereo switch that switches the IC1A input to the IC1B output. This will give you 2 stages of phasing if the LFOs are in phase, and something more complicated if they are out of phase. Will give it a try and see whether it's worth an extra switch.
This is mono-in, stereo-out, so won't quite replace what you have. Doesn't mean you shouldn't consider building something though.
samhay
Quote from: blackieNYC on August 18, 2015, 07:56:53 AM
I have updated the schematic to show input switching to IC1A. I don't know what to call this switch, but it is a nice addition if you are predominantly going to use this a mono effect. The output from IC1A become a lot chewier - as would be expected for a 2 vs 1 stage phase shifter and it works with the LFO phase switch in either position. The stereo sounds ok in this mode, but the effect is obviously less symmetrical.
samhay
Thanks Rob. Does that mean it sounds like arse on anything else?
In any case, I will make a clip of the new Mono/2-stage option, which sounds quite acceptable in mono too.
yes ha ha... ;)
no it means mrs astro was watching the bloody tv... ::)
samhay
Figured I should post an update as I had a question about the digital LFO, which is discussed here:
http://www.diystompboxes.com/smfforum/index.php?topic=109015.0
The project is still alive and I am in the process of building this:
(click for larger version).
I will post code and a vero layout once it it verified and tweaked to my liking.
The pic12F1612 is new and has 2 semi-independent PWM outputs (same frequency, different duty cycle) so it can drive 2 LFOs.
The LFO controls are:
mode 1: depth, speed and phase (arbitrary phase difference between 2 LFOs; 0 - 180o).
mode 2: depth, speed L, speed R (i.e. the speed of the 2 LFOs is independent, but they share a common depth setting).
~arph
Cool, I like the separate phase and speed settings, that is something I have not heard before. Looking forward to hear how that turns out
samhay
Was reminded of this tread today.
Links are all gone thanks to dropbox, so will repost the analogue LFO design. PIC design got put on the 'needs work' pile.
Schematic:
https://www.dropbox.com/s/gun6xwy6993xns1/ACE_tremolo_schematic.jpg
Audio clip:
https://www.dropbox.com/s/svk2ij1nlkjzds6/ACE_tremolo.mp3
Quickie Sam if you don't mind.
Did you try any different values for c7 c8
Say c7 47nf
      C8 68~82nf ?
samhay
I don't recall exactly, but as C7 and C8 are the C's to the LDR's R's, I must have auditioned them to some extent.
I think they were a compromise to get a decent sweep out of both the tremolo (actually a variable HPF) and phase shifter.
By all means, one should tweak these to suit the LDR used.
For reference, it would appear the equivalent cap in the Magnavibe is 100n:
http://revolutiondeux.blogspot.com/2012/01/bigfoot-fx-magnavibe.html
Edit - probably didn't try different values for the 2 stages as I was trying to make them equivalent. Could be interesting. Could be even more nauseating.
samhay
If you give it/something like it a try, please let us know how it goes.
Might give me some impetus to get this working properly again.
