Really weird issue..
Started by dschwartz, August 19, 2015, 08:01:50 AM
dschwartz
Last night i tried to show a friend my last pedal build (a jfet muamp followeb by a boost circuit).he had a fender champion 100 amplifier, which has a dsp preamp..
The thing is, the amp started cutting out, like choking, with the pedal, even at low gain, low volume set..really weird, with other stompboxes it worked fine..
I checked my pedal back home and it worked perfectly..
Does anyone had a similar experience?, an amp that simply wont work with your pedal?
Tubes are overrated!!
http://www.simplifieramp.com
samhay
Any chance you have a leaky output cap?
dschwartz
Dont think so..theres no popping while switching, its a nice panasonic 1uf poly..
A sub sonic oscilation could be the culprit?
A friend had a similar issue with one of the new fenders. apparently they dont take kindly to analogue pedals :(
dschwartz
Quote from: Kipper4 on August 19, 2015, 05:30:21 PM
That's  my hypothesis, but why??
I felt embarrased when it started cutting out..i couldn't  explain  it
