Anyone tried DOD230 noise gate?
Started by nguitar12, September 21, 2015, 08:26:12 AM
nguitar12
Just wonder if anyone here tried a DOD230 noise gate?
Is this schematic verified?
Can I use a TL074 quad opamp in replace of the TL022 and LM358?
Also how do I add a release control in this schematic?
Many thanks.
hymenoptera
The TL022 was probably chosen for low-current reasons. Maybe a TL062 will sub for that one?
"Radio Shack has nothing for anyone who's serious about electronics." - Jeri Ellsworth
FUZZZZzzzz
#2
http://www.diystompboxes.com/smfforum/index.php?topic=81973.20
the person in question got it working in the end.. but you'll need to read a bit ;)
samhay
^Can I use a TL074 quad opamp in replace of the TL022 and LM358?
No. You can replace the TL022 with a TL072, but you need a single supply op-amp like the LM358 for the side chain as it has to work with its input pulled to the ground - see what the switch is doing?
nguitar12
Quote from: samhay on September 21, 2015, 05:13:53 PM
What about using a LM324 single supply quad opamp?
I want to keep the parts count as low as possible.?
Blitz Krieg
Cjuried
Why not try an LM6132 or LT1014 as they are both viable options. You could also go the route of an AD822 or MC33171 / MC33172. Various other options exist.
Chris Juried
Audio Engineering Society (AES) Member
http://www.juriedengineering.com (Juried Engineering, LLC.)
http://www.tubeequipment.com (Tube Equipment Corporation)
http://www.historyofrecording.com (History of Recording)
