Pot and knob compatibility
Started by VidSicious, September 21, 2015, 10:45:57 AM
hymenoptera
Wow, killer selection of colors and styles on the 1900's at Thonk! Loving the Dark Red!
Anybody got a lead on these unusual colors in the USA?
"Radio Shack has nothing for anyone who's serious about electronics." - Jeri Ellsworth
Steve at Thonk is a good bloke and has some interesting stuff. Catering for the wiggling community, but bits and pieces for us too. He keeps some of the 9mm Alpha-like pots, but with an extended shaft, and the little nubs that everyone breaks off are already removed!
36mm Collet Knob at Rockby - 2.5$AU
and others, if you can stand the colour schemes.
^ there should be a 'dislike' button for those...nasty.. :P
Granny Gremlin
#24
Quote from: PRR on September 22, 2015, 01:18:42 PM
Really classy gear has collet knobs. There is a tapered collar inside, somewhat like the chuck on a Dremmel tool, tightened with a screw in the end. Screw head covered with a snap-in cap. These cost $20 or more each, and are not readily available.
They're also a pain in the arse and (often) require a special tool (not cheap) to tighten/remove, AND you end up losing the end caps all the time.
Metal (brass) internal collar w set screw is the best but almost as expensive as the cheaper end cap ones.  A good modern budget alternative are the ones with not a full internal brass ring, but at least a threaded rectangular plate for the screw to screw into (vs screwing into plastic, which is ridiculous and I will not tollerate it), like this:
my (mostly) audio/DIY blog: http://grannygremlinaudio.tumblr.com/
tubegeek
Thonk has just about the best logo I've ever seen.
