Tonepad Boss Chorus CE-2 Stereo Daughterboard Help
Started by nickbungus, September 23, 2015, 07:45:29 AM
nickbungus
Hi All
I have successfully built a Boss CE-2 Chorus using the Tonepad Layout.  I'm really happy with it but would like to add a stereo daughter board.
Heres the Schem and BOM:
I hate vero but Tagboard have a version of the CE-2 with the stereo daughterboard mod.
So what I'm struggling with is where to connect my A, B and C wires on my PCB board to connect to the Vero daughterboard?  Here's what I think:
A:  Anywhere connected to IC1 Pin 1
B:  At a guess at the R22, R20, C14 Junction (Very unsure on this)
C:  Anywhere IC1 Pin 5.  Again, I'm unsure in this.  If I'm reading everything right, on the Tagboard IC1 Pin5 and IC2 Pin 5 are connected, but I don't see that on the Tonepad Schem.
Any advice would be more than welcome.
Thanks.
To the extreme, I rock a mic like a vandal.
Light up a stage and wax a chump like a candle.
you can head back over to tonepad and take a look at the small clone stereo daughter board which should work with the ce2 also.
I did this mod to my rack mount version of the ce2 and was dissapointed. It added nothing going into two differant amps so i made the second output a dry signal. IIRC i tapped it off of the buffer.
have fun
Rich
nickbungus
Thanks Rich for the info but I would still like to give this a whirl.
I'm even more encouraged to try the Vero version if it may be a waste of time.  I prefer to etch than Vero but for such as small circuit I think this is the way to go.
Fender3D
Quote from: nickbungus on September 23, 2015, 07:45:29 AM
A: Yes
B: Yes
C: Yes (better call this point as Vb)
NO!!!!!
IC1 Pin5 is connected to "audio" Vb
while IC2 Pin 5 is connected to "LFO" Vb (R33 R34 node)
nickbungus
Thanks Fender 3D for spending your time on that one.  That's excellent.
Regarding the last point about IC1 and IC2 pin 5s, that's one of the reasons I hate vero.  Its hard to read and follow the circuit (IMO).
nickbungus
That worked a treat, thanks again Fender3D.
I'm yet to try both outputs together but I'm getting Chorusing from both.  I'll let you know Kipper4 if I get the same results as you.
