checking transistor voltages for biasing?
Started by plexi12000, October 03, 2015, 12:50:46 PM
plexi12000
hey...i was wondering, when checking a collector voltage....should signal be going thru the circuit? or ok just with the dc supply on?
it's something i was wondering about. i want to be sure i get an accurate read and all that.  thank you!
No need to plug the guitar in the input mate.
just measure without.
Even more emphatically - you do NOT want signal going through to measure the DC bias conditions. Signals mess that up. You can't trust the readings.
Do your bias readings with zero signal.
