Debugging Crybaby Wah Wah
Started by Ben Lyman, October 22, 2015, 08:52:30 PM
Ben Lyman
My brother's Wah Wah only passes a bypass signal.
It is the kind with SPDT switch.
Here is what baffles me:
1) With switch in active mode, no signal
2) put .01uF cap on the tip of a guitar cord (in series w/input signal) and we get a fully functioning Wah pedal.  :icon_confused:
        -S. Vai
So use that cord.
Or put a 0.01 cap where the cord comes into the pedal.
Or find the cap which *should* be about there, but isn't doing its job, and fix it. Solder blobbed on both ends, missing protoboard trace cut, cap rescued from 1942 radio.....
Ben Lyman
Ya, the possibilities are endless! well I guess I assumed it would be the input cap so we cut it out and replaced it but still doesn't work. it's almost as if there were supposed to be a cap inside the switch or the pot.
He's gonna keep experimenting with it for awhile.
        -S. Vai
