Source for the Alpha 16mm SPST On/Off fuzz pot?
Started by Nocaster Cat, November 24, 2015, 08:57:20 PM
Nocaster Cat
Mouser used to carry them but it looks as though they're breaking away from Alpha. I'm looking for a B1K with solder lugs, thanks.
smallbearelec
Quote from: Nocaster Cat on November 24, 2015, 08:57:20 PM
When I enter the Mouser number 313-1100F on -line, the results show the parts with the 20-type (PC Vertical) terminal. But the Alpha part number shows the 10-type term, which is solder lug. You might confirm with Mouser which you actually get. Sorry I can't help you immediately; Analog Mike asked me to carry these for customers who want them for repairs, and I keep forgetting to add them to our regular factory order.
Nocaster Cat
Quote from: smallbearelec on November 24, 2015, 10:55:57 PM
Steve...will you be carrying them at some point?
I've used the ones made by CTS, small in size however, not cheap and they have a 1/8" shaft so you need to find or make a bushing to use with 1/4" hole knobs.
(Canadian dollars)
http://www.digikey.ca/product-detail/en/270X232A102B1B1/CT2224-ND/203805
dave
smallbearelec
Quote from: Nocaster Cat on November 25, 2015, 01:19:41 PM
At some point, yes. I'll order one from Mouser and see if, as I suspect, the posted pic is wrong. If so, I'll order a few more from them and sell at a small loss. Will then order bulk from the factory for delivery on the boat in February.
Nocaster Cat
Quote from: smallbearelec on November 25, 2015, 07:46:22 PM
Cool, thanks!
