EHX Small Clone Blend Mod - please verify
Started by LiquidMetal, December 24, 2015, 12:30:50 AM
LiquidMetal
Hello,
I got an EHX Small Clone chorus with plans to implement the Depth mod as described here: http://experimentalistsanonymous.com/board/index.php?topic=1578.0
There are a couple of other mods on that page, but one thing that is missing is a blend mod. I like the Small Clone a lot, but it would be nice to make it a bit more subtle.
The schematic is available here: http://www.freeinfosociety.com/media.php?id=4100. It looks the schematic is for the original (FET-switching, not the new TB) effect, but I assume it could be used as a starting point.
My question is: if I replace the 22K and 27K resistors (the voltage divider at the top) with a 50K potentiometer, is this going to allow me to blend the dry and wet signals as intended?
Also, I am not sure if this will require to rebias every time the blend ratio changes using the bias trip pot (I hope not).
Thanks in advance!
Yes replacing those resistors with a 50k pot will work, it won't need rebiasing for different settings. At extreme settings there will probably be a noticeably volume increase but if you only want to make small changes to the mix that won't be a problem.
