Replacing 3P2T footswitch with 2P2T toggle switch
Started by SmallMuff, December 27, 2015, 12:11:33 PM
SmallMuff
Folks,
I'm working on an unusual project - building a MKII Tonebender clone into a Danelectro DC59  :P -  and I was hoping to get some advice on switch wiring.
I've build the kit and it's working beautifully, but I'm hoping to replace the standard foot-switch with a toggle switch.  The problems is the standard footswitch has three poles (9 pins)  and the toggle only has two poles (6 pins). Is it possible to rewire the configuration?
Any help would be greatly appreciated! :icon_rolleyes:
Cheers,
Gert
armdnrdy
You can use the DPDT toggle if you don't mind losing the LED.
There are other options such as connecting the Tonebender circuit "non true bypass" or purchasing a 3PDT toggle switch.
SmallMuff
Thanks. I've lost the LED and will give it a spin.
Ice-9
Or use 2pdt with millennium bypass or just buy a 3pdt toggle switch to wire as your working pedal.
www.stanleyfx.co.uk
SmallMuff
Thanks Ice-9! I'll give the millennium circuit a try.
