LPB positive ground by swapping 2n5088 for 2n5087
Started by Chris S, January 01, 2016, 09:09:23 PM
Chris S
Hey all can I just swap the 2n5088 in an LPB for a 2n5087 and then it's positive ground instead of the usual negative ground?
(Why? I have a banjo with a positive ground active acoustic pickup I wanted to mix this with a regular guitar pickup but that needs a little bit of a boost to be as loud as my other guitars so I wanted to add the LPB and would rather swap a transistor than add the max1044 +Ve and & -Ve from one battery circuit)
If any caps are electrolytic (I can't remember), turn them around.
Whether the stand-alone LPB has it or not, a LPB on the same supply as anything else *should* have a >50uFd cap across the power rail to damp sneakage through the supply to the other stage(s).
Chris S
