LED always on?
Started by bifbangpow, January 04, 2016, 05:44:06 PM
bifbangpow
What would cause the LED to turn on, the minute a battery is plugged in (even when there is nothing in the input/ouput jacks)?
Using the general guitar gadgets instructions and layout for the Big Muff Pi (ram mod). Measurements will be in this post soon... still taking them.
Here's a link to the diagram: http://www.generalguitargadgets.com/pdf/ggg_bmp_wiring.pdf
M
Keep on keepn on.
mth5044
It means you have a short somewhere that allows the circuit to complete. A link to the wiring guide is helpful. I'm guessing they have you switch ground, might want to start with the switch. Make sure there is not continuity between the anode of the LED to ground when the switch is in the off setting.
bifbangpow
Thanks! I'll focus my efforts there.
Keep on keepn on.
mth5044
Could also have the anode grounded against the case.
bifbangpow
Im trying to add an image here but I'm not sure how. I thought I knew how but it aint working.
Keep on keepn on.
mth5044
You can host it elsewhere, such as photobucket or imgur, then post the address between [img ] [/img ] tags, without the space.
