SD-1 passing too much dry signal after mods
Started by RPercival, January 04, 2016, 08:08:32 PM
RPercival
I recently finished modding my SD-1 with mods published in this thread:
http://www.diystompboxes.com/smfforum/index.php?topic=96462.0
I tested it at low volume and it seemed to work fine. I shelved it for a few week and when I ran it through my big rig, it passes way too much clean signal. It's almost as if I'm blending a clean and dirty amp but the louder I use it, the more clean I hear. Anyone have any experience with this or know what could cause it? Thanks in advance!
Ben Lyman
I remember this happening before to someone so I searched. Sorry I can't help you but at least I can give your query a bump and maybe someone else will have answers ;)
Here, read through this and be sure to check the links within it: http://www.diystompboxes.com/smfforum/index.php?topic=112365.msg1036828;topicseen#msg1036828
        -S. Vai
RPercival
Thanks for helping. That guy seems to have the same issue as I but the links in the thread are for wet signal bleeding when the effect is turned off. I'm going to carefully go over all my solders and double check all the component values I changed. Something has to be messed up somewhere.
