A/B/ab switch where ab has one amp has a isolated ground constant. No leds simpl
Started by FaithElectronix, January 07, 2016, 02:23:56 AM
FaithElectronix
Wanted to convert my old line 6 fbv2 footswitch into an aby switcher without leds and my switches only have 3 posts.
S.K. Latham
FaithElectronix
Also, what size drill bit is needed for 1/4" jacks? I forgot 10 or 11mm?
S.K. Latham
Quote from: FaithElectronix on January 07, 2016, 02:25:39 AM
Depends on the jack.  Mine are all 9mm.  But get yourself a step bit, rather than one bit for each hole you anticipate drilling.
FaithElectronix
Basically my switches only have 3 prongs and how to make one, without any groundlift.
S.K. Latham
mth5044
If they only have three 'prongs', it sounds like they are SPDT switches. They might also be momentary. You need at least DPDT.
