EHX Mole/Hog
Started by pjones78, January 21, 2016, 02:32:19 PM
pjones78
When comparing the two schematics, which would be the better foot to go with?
Huuuu they're identical.......
pjones78
There are a few cap and resistor differences, that's why I asked?
anotherjim
Top one has level control on input while on the lower it's on the output.
Top has a lower input impedance too as well as a fixed reduction of the input level even with the control at max.
Which one suits your guitar might well depend on it's pickups/impedance. I've not tried either so I can't help you decide.
Which ?
Edit
Gottya Jim. I couldn't even see that on my phone. Between jobs @work.
I need an eye test.........
why not go the whole hog's foot, and build it with both pots? I've even given you a name for it.
and kipper - how many fingers?
anotherjim
Ah so -  they're both bass boosters? Probably a bit like a DI into a Portastudio channel sound.
If your bass is active, the pot-first type might be best & the pot-last for passive.
Quote from: duck_arse on January 22, 2016, 09:35:59 AM
Two....... :)
Meanderthal
#8
Go with the second one, with the volume pot at the tail end. Uses one less resistor, theoretically should be quieter, and I've built it several times, works great... Also, if you really want volume control in front of the circuit For whatever reason, you can just use the one on your bass
