Author Topic: Relay Bypass with "latch" function  (Read 8627 times)
Benoi31
« on: January 25, 2016, 05:13:37 AM »
Hello !
Do you know if there are any relay bypass PCB out there with a "latch / unlatch" function ?
I mean the possibility to wire a switch that would let you choose between normal switching or a temporary switching while your foot is on the switch.
I am currently designing a tremolo, and I think it could be a nice feature to add to it (especially with square waves)
I am also learning PIC programming, but relay bypass is not as easy as it seems to program... And I find the lack of source code disturbing for such a project that could be a great way to learn PIC programming.
For now I am really a beginner (light up a LED, sense a switch), but if by any chance I manage to get the code right, I will try to make a tutorial on my blog;
Thank you !
Benoit
samhay
Re: Relay Bypass with "latch" function
« Reply #1 on: January 25, 2016, 08:40:48 AM »
If you can turn an LED on and off with a PIC, you can do the same with a non-latching relay.
Are you using Assembly or C?
« Reply #2 on: January 25, 2016, 01:04:41 PM »
With a micro controller it's possible to detect between a switch being pressed and then quickly released and one being pressed and held down so you could do your latch/unlatch switching without a second switch to choose which.
I'm working on something that does this at the moment, not for switching a relay but the idea is the same, I can post some example code if you like.
Benoi31
« Reply #3 on: January 25, 2016, 04:42:21 PM »
Hello,
thanks for the replies,
for now, I am using Basic (weird huh? but I have some background with it, it helps a bit)
cloudscapes
« Reply #4 on: January 25, 2016, 07:48:30 PM »
are you using bascom? if so, I can share my bascom code for relay bypass. comes with debounce.
Code: [Select]
$regfile = "atTiny85.dat"
$crystal = 1000000
Config Pinb.2 = Output                                      'LED
Config Pinb.3 = Output                                      'Relay 1
Config Pinb.4 = Output                                      'Relay 2
Config Pinb.0 = Input                                       ' Stomp
Dim Bypass As Boolean
Dim Button As Boolean
'default
Pinb.2 = 0
Bypass = 1
Button = 0
Portb.3 = 1
Portb.4 = 0
Waitms 5
Portb.3 = 0
Portb.4 = 0
Do
   If Pinb.0 = 1 Then
      Waitms 20
      If Pinb.0 = 1 Then                                    'debounce
         If Bypass = 1 And Button = 0 Then
            Portb.2 = 1
            Bypass = 0
            Portb.3 = 0
            Portb.4 = 1
            Button = 1
         Elseif Bypass = 0 And Button = 0 Then
            Portb.2 = 0
            Bypass = 1
            Portb.3 = 1
            Portb.4 = 0
            Button = 1
         End If
         Waitms 5
         Portb.3 = 0
         Portb.4 = 0
      End If
   End If
   If Pinb.0 = 0 And Button = 1 Then
      Button = 0
   End If
   Waitms 10
Loop
End
{DIY blog}
{www.dronecloud.org}
samhay
« Reply #5 on: January 26, 2016, 03:33:54 AM »
>with a micro controller it's possible to detect between a switch being pressed and then quickly released and one being pressed and held down so you could do your latch/unlatch switching without a second switch to choose which.
I like to do this to save a footswitch and have previously posted some rough code that does this here:
http://www.diystompboxes.com/smfforum/index.php?topic=107226.msg1013314#msg1013314
Benoi31
« Reply #6 on: January 26, 2016, 04:39:32 AM »
Wow!
Thank you all!
Time to decipher all of this now
Hatredman
« Reply #7 on: February 07, 2016, 08:41:03 AM »
With a micro controller it's possible to detect between a switch being pressed and then quickly released and one being pressed and held down so you could do your latch/unlatch switching without a second switch...
Does it need to be microprocessed?
On a school I went to, all classrooms had slide projectors with ONE push button for operation. Press and quick release, next slide. Press and hold, previous slide.
It was in the seventies, I really doubt it was microprocessed.
Kirk Hammet invented the Burst Box.
Benoi31
« Reply #8 on: February 08, 2016, 04:28:38 AM »
You can do it with FET switching (like on some old Boss pedals), but it is rather a big system compared to a microprocessor scheme, and I figured out that it was a good way to start learning programming PICs. (which is always useful, right ? ^^)
For now my PIC is blinking a LED when I press a button, so I am waiting to receive the relays and it should be done (or I hope so)
I had hard time finding which software to use, how to emulate a Pic...etc, but finally managed to do it.
Hatredman
« Reply #9 on: February 08, 2016, 08:21:51 AM »
Hummm, care to share?
Benoi31
« Reply #10 on: February 08, 2016, 11:49:01 AM »
No problem of course!
I decided to use MPlab X, and a PicKit 2 with an adaptator (this one precisely: http://www.ebay.fr/itm/PICkit2-PIC-KIT2-debugger-programmer-for-dsPIC-PIC32-PIC24-Logifind-adapter-UK-/272114170848?var=&hash=item3f5b44bbe0:m:mIELUS3LF9UEks5m_qdscVw )
MPLab is quite complex to handle, but this video presents well how to start:
https://www.youtube.com/watch?v=mUofSucHx_E
To test my code before burning the chip, I used Real Pic Simulator:
http://digitalelectrosoft.com/pic-simulator
« Last Edit: February 08, 2016, 11:50:40 AM by Benoi31 »
Benoi31
« Reply #11 on: February 10, 2016, 10:26:42 AM »
Code: [Select]
$crystal = 1000000
'default
Pinb.2 = 0
Bypass = 1
Button = 0
Portb.3 = 1
Portb.4 = 0
Waitms 5
Portb.3 = 0
Portb.4 = 0
Do
   If Pinb.0 = 1 Then
      Waitms 20
            Portb.2 = 1
            Bypass = 0
            Portb.3 = 0
            Portb.4 = 1
            Button = 1
            Portb.2 = 0
            Bypass = 1
            Portb.3 = 1
            Portb.4 = 0
            Button = 1
         End If
         Waitms 5
         Portb.3 = 0
         Portb.4 = 0
      End If
   End If
      Button = 0
   End If
   Waitms 10
Loop
End
I have now a code that is pretty similar to this one (in C though).
Samhay, why do you use shadow registers for sGPIO? I am not familiar with this concept.
Is 200 ms enough to differentiate a long press and a short press of the switch?
Also, is a debounce counter really better than a simple  :
Code: [Select]
if switch =1
    __wait_ms(20)
    if switch = 1
        change state
Thank you for your help
« Last Edit: February 10, 2016, 10:28:36 AM by Benoi31 »
samhay
« Reply #12 on: February 10, 2016, 11:58:46 AM »
It's often not necessary, but can be good practice with the basic PICs as it prevents read/modify/write errors. If you google 'shadow register' you should find plenty of more thorough explanation.
caldersm
« Reply #13 on: February 11, 2016, 04:27:05 PM »
Benoit,
I finished some code doing just that in an application. If you pressed and held the foot switch down for 3 seconds it would program that switch to output a 100 msec pulse, instead of latching it the switch output on and off.  Holding the switch down for another 3 seconds would switch it to a normal latching on/off mode.
Basically, you look for the switch press to be a "0"(that is ON) and start to increment a timer and if it exceeds a certain amount, then you set a bit to change the switch function after the switch is released.  Below find the Check Switch function written in C.  Reacting to whether Prg = 1 or Prg = 0 is in another subroutine.
void Check_Switch_Pressed() {
 while (digitalRead(Pin_Sw[Switch]) == 0) { //Is Key pressed on current Switch(Press = Zero)
    hold_delay++;  //Each hold delay is equal to 50ms....add 1 to here.
    time_delay = (hold_delay * 50)/1000;  //Each time delay is equal to 1sec
    delay(50);  //Go to sleep for 50ms for Switch debounce
    if(time_delay >= 3 && time_delay <= 5 && Prg == 0) { //If switch is held >= 3secs and <= 5secs Then
      Prg = 1;  //Set Program Mode Bit to execute Program Mode Code when Switch is Released.
      Slow_Flasher(3);  //Flash Button LED 3 times to Let User know they are in Program Mode
Benoi31
« Reply #14 on: February 12, 2016, 03:02:52 AM »
Yeah it works for the switching part  :)
Just miss the relay (currently waiting for parts..)
Do you need a transistor to drive the relay? What is the maximum output current of a PIC 12F675? I read 20 mA somewhere, but I am not sure... I ordered 100mW switching relay, it should be enough (or I hope so!)
I am now working on the temporary mod, set with a switch.
Code: [Select]
Clever, but I rather use an external switch for now (better with my current design of the pedal)
I am going to configure the last GPIO as an input for the switch (with values of 5V or 0V - 1 or 0), and I will add a if / else in the code architecture to make the activation temporary.
« Last Edit: February 12, 2016, 04:00:15 AM by Benoi31 »
samhay
« Reply #15 on: February 13, 2016, 03:14:39 AM »
Almost certainly yes. I have used both MOSFETS and relatively high gain BJTs.
Benoi31
« Reply #16 on: February 15, 2016, 06:34:39 AM »
Ok so my code works for momentary activation now, with an external switch to choose between the two modes. I am quite proud of myself  :icon_mrgreen: (I know, this is complete beginner stuff, but still, feels good to make something that works!)
I am still waiting for the relay to be in my mailbox. I'll try to add a transistor to drive the relay
I also noticed that some people use an optofet to silence the switch while switching (http://www.diystompboxes.com/smfforum/index.php?topic=112029.0)
Do you think it is necessary? Is the amount of "clicking" noises important with a simple relay scheme?
Thank you all!
I'll try to post my code this evening if that is of any help
« Last Edit: February 15, 2016, 06:46:11 AM by Benoi31 »
samhay
« Reply #17 on: February 15, 2016, 03:13:39 PM »
Well done - sounds like good progress.
As far as switch noise / bounce goes. I have only one pedal (with a relay) where this is a problem. A mute (optoFET or otherwise) might help, but I would treat this on a case-by-case basis.
Benoi31
« Reply #18 on: March 14, 2016, 06:10:26 AM »
Hello !
So, just to let you know, I prototyped the PIC on my breadboard, and everything worked, even without a transistor to amplify the current to activate the relay :)
I used a relay that is slightly bigger than the classic Panasonic TQ2L, and that is also way cheaper, a Takamisawa NA05W-K.
I conceive a small PCB that can fit in 1590A enclosure, currently waiting for it
Switch 1 is the soft SPST switch, and switch 2 is an optionnal switch to choose between momentary and "normal" activation of the effect.
Benoi31
« Reply #19 on: April 17, 2016, 02:47:48 PM »
Hello everyone, I wrote a full blog post about relay bypass on my blog. Unfortunately, I only have the french version for now, but the english one should be released soon.
At least, the source code is there :
http://www.coda-effects.fr/2016/04/relay-bypass-mise-au-point-et.html
