Madbean's new current lover problem-SOLVED
Started by darrenw.sparky, February 01, 2016, 08:51:16 AM
darrenw.sparky
Anyone built the new 1 yet?
The madbean forum seems to be down...again!
My problem is R42--22ohm, when power is connected up it starts to burn out? should i try a 1/2W instead of the 1/4W orr is there something else going on?
do you have a reverse protection diode on your build? if so, check, check, and check again that it is the right way around. it sounds like you have a short of some description, drawing excessive current.
darrenw.sparky
my LM324 was wrong way around, all working now
thats what you get for building at 3am!
jimilee
Nothing good ever happens after the sun goes  down!
Elijah-Baley
