soldering wire to straight lugs?
Started by bifbangpow, March 12, 2016, 02:54:06 PM
Jdansti
^ Could you please explain that again?   ;D
Giglawyer
Check out my builds - http://www.giglawyer.com
karbomusic
I pre tin the wire and the lug and 'lean' it against the post when soldering so it doesn't move as the solder cools. I need it this way because I run heatshrink over it which solves more longevity problems IMHO than bending/wrapping etc. does.
Jdansti
Quote from: induction on March 12, 2016, 06:16:04 PM
Or use a small piece of vero:
This is a particularly good way to solder those little green 9mm pots from Tayda. The lugs are so close together and flex very easily. Even if you use heat shrink to insulate them, they could break after a few bends.
J0K3RX
You can strip the wires back enough, then thread the wire through the small eyelet holes and solder them to the lug on the other side. That gives it some strain relief and doesn't allow them to bend at the lugs..  :icon_wink:
Jdansti
#25
These are the type that I was saying work best with a piece of vero. The legs are very soft.
Edit:
Actually, these.
J0K3RX
I made this for the clear shaft... maybe too much trouble for most people to etch but if not then here ya go. You can use them for LED lit or standard..
Transfer 50 count
https://dl.dropboxusercontent.com/u/11178619/POTS/9mm%20pcb%20mount%20cs.pdf
Jdansti
^Nice! Where you got dem clear shafts?
J0K3RX
Jdansti
