Calling all fuzz guys, looking for a build
Started by Screamingdeal, March 27, 2016, 09:32:19 PM
Screamingdeal
Similar to the greenhouse sludgehammer. Check the review on the youtube by Ryan Bruce. Now I am not a fuzz guy, never owned one, but this pedal has changed my mind. I am a big fan of sludge bands like Down, Crowbar, Eye hate God and the like. If anyone can point me in the direction of a fuzz build that has the tone and sound similar to the sludgehammer I would appreciate it.
nocentelli
Is that it Leo?
Buffer >500x gain stage> SRPP and tone control.
The srpp will be noisey/fuzzy on its own.
mac
What about removing the buffer, or placing it at the output.
mac
exztinct01
i loved the sound of that pedal too. Hope someone can give the exact schematic of that circuit.
~ Stephen
nocentelli
Quote from: Kipper4 on March 28, 2016, 06:07:18 AM
Is that it Leo?
It's from a trace of an original unit at the other place:
http://tinyurl.com/zyxbtyh
Thanks Leo.
Theres your schematic then guys.
exztinct01
~ Stephen
Gus
nocentelli
is that schematic correct?  I don't like the "design"
If one looks close it is gain stages into something like a BMP tone control(50K and 10k loading of the tone control?)
I would adjust a muff circuit
nocentelli
Quote from: Screamingdeal on March 27, 2016, 09:32:19 PMCalling all fuzz guys, looking for a build..... Similar to the greenhouse sludgehammer.
Gus, if you look at the gutshots in the link I provided, you will be able to judge for yourself how close the schematic is to the Greenhouse sludgehammer that OP requested (I did not trace it, I assume deafbutpicky drew what he could see and guess from the pictures provided by Jooshtin). I'm also not that keen on the overdriven muamp thing, but I'm not a big fan of the BMP tonestack either.
" I'm also not that keen on the overdriven muamp thing,"
I agree with you there Leo.
I built the Shaka 5 and it was much better without the mu amp and still had loads of volume.
mac
Quoteis that schematic correct?  I don't like the "design"
I agree.
The input impedance of the opamp gain stage is big enough, I don't know if the input buffer is needed.
And as Gus noted, there is some loading at the output, so the input buffer could be adapted as a recovery stage or output buffer to make the tone control independent of whatever comes next.
mac
Screamingdeal
Found another fuzz called black goat fuzz. It's a beast too. Should be easy to modify a tone bender or a fuzz face.
nocentelli
Quote from: Screamingdeal on April 02, 2016, 11:52:20 PM
Roland Bee Baa clone?
Gus
#15
[/quote]
I did not look at the link.
Maybe the first poster should test a IC BMP like circuit.
deafbutpicky
the red traces are assumptions as I couldn't see what's beneath the op amp on the pictures.
I'd say it's totally reasonable to put this at the end of the tonestack.
BTW I put the  tonestack buffered into my tube overdrive and really like the sounds I can get with it.
values: cap to ground 68n, parallel cap 47n, no modern, no bypass cap on tone pot, 510 ohm
series resistance to body pot.
