True Bypass with NE555 Flip-Flop
Started by antonioalvino, April 19, 2016, 08:01:00 AM
antonioalvino
Hi
I have this scheme, for true bypass switch with very fast change
can someone help me with the pcb? I do not know.
http://it.tinypic.com/usermedia.php?uo=uW4M4OjFxsbuMC69m5NUk4h4l5k2TGxc#.VxYdzD9MLrk
Jdansti
Nice! I assume that the ground for the 555 would be the same ground as your effect. In my experience of using 555s as a tremolo LFO, it can be difficult to prevent the 555 from causing a "pop" that can be heard through your amp. Have you tested an effect connected to the relay while using the same ground as the flip flop circuit?
