Is there a DIY "Nano Big Muff Pi"?
Started by rbarone, April 21, 2016, 07:02:42 PM
rbarone
Title really says it all...  Nano Big Muff Pi -  Noobie wondering if such a project exists.  Thank You All.
stonerbox
Just pick a layout/model you fancy, order the components in SMD and build it.  :icon_biggrin: However EH are known for components changes in their Big Muff builds and I am afraid the Nano is not that well documented, at the time being.
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
aion
This will get you there:
https://aionelectronics.com/project/halo-ehx-big-muff-fuzz-pcb/
Same size enclosure, same knob layout, and you can build any BMP variant you want with it. Pretty good newbie project compared to some other circuits.
If you're trying to save money, I doubt you could do it for less than the cost of a real Nano - but if you're doing it for the experience and the thrill of having something customized, you're in the right spot!
JustinFun
My smd layout is pretty tiny - 5.25cm by 2.25cm. If you use board mounted pots it sits quite happily vertically in an enclosure.
You need the .diy file to get the component values really as it's so packed in - and also for the solder mask, hopefully this link will work:
https://drive.google.com/open?id=0B8kEUJAyrC36aC1nbUdxa0d1WXM
I've built a couple of these so it's verified by me.
JustinFun
Just realised that I made a later revised version to use smd transistors as well - this is the version I have actually used and verified. The layout pic is a bit more user-friendly as well.
etch file here:
https://drive.google.com/open?id=1E8OkF5Wkglrr5Rhyrl0J1Q4vwtIeMuV_Wo3C116T5UVIzA-rpHOE-9KyzsZNfO75EqvVyC2GIeTG0y8a
287m
if just for 1590A-ish Big Muff Pi
the layout below has designed to fit in 1590A with 9mm onboard pots, led onboard, and BC550 pinout
can build with big caps (4 hole) too, for greenies fans  :icon_mrgreen:
easy convert to perf, 13x21 , just one jumper (R6x) or you can eliminate that with looong R6  :icon_twisted:
Justinfun : awesome! like your style!
LiLFX
I have a one-knob Big Muff using 0805 resistors/caps and SOT-23 semiconductors.
midwayfair
The BMP will fit on perfboard with through-hole components in a 1590A. A 1590B is hardly unusual.
Madbean's Mudbunny is a pretty much flawless layout of the circuit designed for a 1590B. http://www.madbeanpedals.com/projects/
Les Paul Lover
I've built the fuzz dog pedal part BMP circuit in 1590B. Whilst I have one 1590A pedal, I don't plan on building anymore - they're aren't stable enough when stomped. They easily topple sideways, I don't really understand the nano craze.
Sent from my D6603 using Tapatalk
