Metronome with tap tempo option
Started by Mgt280y, April 28, 2016, 05:54:35 AM
Mgt280y
Good morning,
Appolgise if this has been done,
I wanted to build a electronic metronome with led indication non audio, that can be set by a pot to a specific tempo (for practice) or a tap input to manually set, a numerical current tempo display would be awsome but not essential
A schematic would be very much appreciated
Thanks in advance
Dan
Want to try and build it into an enclosure around the size of the standard tc electronics flashback 4 dial model
Mgt280y
I have seen this when looking through the net, only thing is the tap input picks up like a looper you tap a pattern three times to reproduce im looking more to be able to use a foot switch and it adjust the tempo as you tap if that makes sence
Mgt280y
Thats the right idea, just need to find a circuit as i would rather use a pcb version and find a way to have the option of either tap via foot switch or dial in with trim dont even know where to start when it comes to a bpm display
Drew47
Hate to bump, but I'm interested in the same project. Did you get anywhere with this?
